Thanks, is there any simple way to test to see if that is generating a "signal" by checking something at the wires in the hole in the dash that hooks up to the speedo?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-21-2011, 07:49 PM
Thumbs up
Replace the gear in my Speedo today, works great. This surely would not have been an easy task without these perfect instructions / pictures. Even works for us germans.
THANK YOU VERY, VERY MUCH FOR TAKING THE TIME AND SHARING!!
Old 05-26-2011, 02:10 PM
Follow me
seymore's Avatar
Thrasher, I have the same number on my face as you,(930 641 508 00) I am wondering how many teeth were on the gear you ordered? There is no gear left for me to count. Thanks
1982 911SC
Old 08-09-2011, 09:57 PM
Thrasher's Avatar
It's been over 5 years, and I'm not having luck finding a confirmation email from the company that may have the part number or tooth count, but this is where I got mine and there is only one option for an '84 (which is what I have): Odometer Gears
It says 20 large/outer teeth and 30 small/inner teeth. Sounds about right.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 08-10-2011, 06:57 AM
Call them. They are very helpful.
Old 08-10-2011, 07:05 AM
Lorenfb's Avatar
"I've had some luck removing the needles on VDO speedos by using two butter knives."
- db_cooper -
Really a bad idea!!!!! As that's the fastest way to remove the shaft with the needle.
Stick to recommending how to find an air leak as a solution for ALL engine problems.
Bottom line: Just send the speedo to Pelican, as they have a speedo rebuilding service.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 09-12-2011, 06:40 PM
Fleabit peanut monkey
Bob Kontak's Avatar
- db_cooper -
lorenfb, I did a search on your posts and found a lot of the data you spew out is no more on target than mine. It's just technically refined. You own or work at a company that rebuilds ECU's. You could be an asset to this forum.
You ain't nothing in my book. Just a flake like you call everybody else.
http://forums.pelicanparts.com/porsche-911-technical-forum/183929-cruise-control-driving-me-nuts.html
Old 09-13-2011, 06:03 PM
Weekend Mechanic
vulcan300's Avatar
If you want to remove the needle without causing damage, you rotate it all the way until it stops, and then continue applying gentle twisting force until the needle turns on the shaft. As the needle turns, pull gently, and the needle will begin the come off of the shaft. Just continue to twist and pull until the needle comes off of the shaft.
With the needle removed you can then remove the face, which will make the repair of the odometer gear a lot easier.
J
86 911 Carrera Targa
Old 09-13-2011, 08:47 PM
Thanks for sharing your techniques on how to get it off Loren.
Since no one on this board does this for a living you should always take your car to a pro and never buy anything from Pelican.
Rick
88 Cab
Old 09-13-2011, 09:25 PM
Lorenfb's Avatar
"If you want to remove the needle without causing damage, you rotate it all the way until it stops, and then continue applying gentle twisting force until the needle turns on the shaft. As the needle turns, pull gently, and the needle will begin the come off of the shaft. Just continue to twist and pull until the needle comes off of the shaft."
That's exactly right on!
See, there're are some (not many) who can think and not just copy & post irrelevant suggestions,
e.g. "check for air leaks" (Bob Kontak/JB_Cooper).
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 09-13-2011, 09:48 PM
Weekend Mechanic
vulcan300's Avatar
I can't take credit for the twist and pull method. I read it somewhere on the forum a while back when I did my own repair. It's good advice and worth repeating though! Much like the seat switch fix using a bottle of aerosol contact cleaner.
Old 09-14-2011, 09:28 PM
Lorenfb's Avatar
"I can't take credit for the twist and pull method."
But you did provide it and probably saved someone from damaging a speedo.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 09-14-2011, 09:51 PM
Undocumented User
McLaren-TAG's Avatar
I have a variation that after reading through this entire thread, couldn't find and answer. My issue is with the odometer on an 86 coupe. The odometer does work, but it takes a few miles of driving for it to begin working. It starts out not moving at all, in a few miles it begins counting up at a rate of about 30% actual mileage, and within 10 or 15 minutes of driving it's back up to 100% accuracy in mileage. The speedometer works without issue.
So my question is, since the odometer does work eventually, the issue seems to me that something (the gear) is slipping and only when it warms up, it expands enough to firmly grasp the shaft and begin to turn properly.
So before I delve into the repair, any suggestions on who I find the actual gear that I'll need so I can purchase it ahead of time and if indeed my gear is not broken but slipping, can I simply try a drop of glue on the shaft? Any other suggestions welcomed.
Old 12-01-2011, 06:14 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Pelican has the gears, but I don't think glue on the shaft will help. There is lots of grease in there.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 12-01-2011, 06:18 AM
Thrasher's Avatar
+1
My guess is your gear's teeth are just worn and the meshing gear is slipping.
Old 12-01-2011, 06:58 AM
John St. Louis's Avatar
How do you remove the three wires on the back of the speedometer that go in to the red connectors on the picture above? Thanks
Old 12-10-2011, 08:57 AM
Wash. State
nesslar's Avatar
You mean the wires going to the three lamps, I'm sure. Just slipa knife blade under the silver 'flange' next to the body of the speedo and gentlly pry up. It can be done with just fingernails, actually. Then you just pull the lampholder out.
Old 12-10-2011, 09:03 AM
80sc
speedometer odometer gear replacement
great help on your thread took me three hours and for those screws i used after loosening them with a small eyeglasses screwdriver was a medical clamp called a hemostat when the speedo arm was touching the faceplate i removed the two screws holding the shaft assembly assembly too easy with clamps then final snug with screwdriver
Old 06-28-2012, 05:02 PM
anyone have a video of how to remove the speedo needle.?, better yet, the whole process of removal? (I am a visual person.) Not being familiar with a lot of the process its hard to visualize the "twist and turn"
thanks,
Aircool
Old 07-29-2012, 01:30 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Just imagine yourself grabbing the head of a bolt or screw that is screwed into something and then 'unscrew' it slowly using light upwards pulling pressure.
Old 07-29-2012, 01:58 PM
