H4's suck??
What is up with h4 head lights?? The high beams work great but the low beams seam like I have oil lanterns for head lights. I have a relay kit installed Am I missing something?? I think I have 50W and 55W low high bulbs. Any input?????
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-13-2005, 08:28 AM
Harlan Chinn's Avatar
Get higher wattage bulbs from our host.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 05-13-2005, 08:36 AM
Me like track days
Craig 930 RS's Avatar
Still, that is odd. Foggy inside with the famous H4 residue?
I think something else here is at play - possibly an electrical problem
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-13-2005, 08:41 AM
Are your headlights adjusted correctly?
What voltage do you get at the bulb with the car running?
road chips degrade optics. DOT lens sucks. and definately tarnished reflectors and adjustment.
I guess these are Bosch H-4's ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2005, 08:48 AM
You must have something wrong with your lights or electrical system. In proper working condition, H4s, even with stock lights, work very well. Certainly would not be confused with oil lamps!
Old 05-13-2005, 08:52 AM
Registered abUser
TerryH's Avatar
yeah, what Brian said.
I recently installed H4's with the stock bulbs and I'm amazed the candlepower. I keep thinking I'm aiming too high, but it's just a lot of light.
'81 911SC Coupe SOLD
Old 05-13-2005, 08:59 AM
hummm.. that make sense.
maybe a voltmeter test with lights on at the headlight bulb socket and compare to battery voltage for a quick test.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Friend of Warren
I agree. Something not right with your low beams.
Kurt V
Old 05-13-2005, 09:00 AM
Carl83911's Avatar
Same here, just recently installed H4's and they're much brighter than the stock. The beam pattern should look like this _____/ .
Carl,
Old 05-13-2005, 09:02 AM
stefang's Avatar
Did you install relays and headlights at the same time? perhaps something is wrong with the low beam relay.
Stef
Old 05-13-2005, 09:03 AM
Carl83911's Avatar
Maybe you hooked up your 'City Lights"?
Carl,
Old 05-13-2005, 09:04 AM
No city lights.. They are brand new bosch h4-s eruo Installed the relay kit at the same time. Maybe not getting good contact through the factory relays?? The sucros kit worked well. The low beams just suck the high works great.
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-13-2005, 09:32 AM
pwd72s's Avatar
Amen!
Old 05-13-2005, 09:45 AM
if the wires are mixed up in the plugs, and they ground through the wrong terminal, the lighting suffers. maybe the reflectors have deteriorated.
206 637 4071
Old 05-13-2005, 09:48 AM
John,
They are brand new lights but may be that they are grounded wrong so can anyone give a pic of the correct plug wiring???so I can verify
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-13-2005, 09:52 AM
think I found the problem found a pic that arego had from a while ago.. Wow this will be nice when correct
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-13-2005, 10:26 AM
Diss Member
Quicksilver's Avatar
One detail. A stock DOT H4 bulb is 55W low beam and 60W high beam. You mentioned 50/55 but that may be a typo...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-13-2005, 11:25 AM
Bill Verburg's Avatar
It also depends onwhat you are comparing them w/ My 55/100 H4s used to seem awsome, but now pale after using modern HIDs
Bill Verburg
Old 05-13-2005, 01:53 PM
lateapex911's Avatar
and on that note...is there a kit that can correctly install HIDs into an early car? Not a bulb, the entire reflector bulb, transformers and lenses? If so, what, where, how much and how successful is it?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-13-2005, 02:32 PM
