Ayo Irpin, Ukraine!
70SATMan's Avatar
Originally Posted by lateapex911 View Post
On the blue car what is the inside of the engine cover??? And what’s up with the heater hoses ?
A terrible idea,,,,,trying to look cool. Pepita seat material. Moisture, dirt grease, oil…rust.
Hey, what could go wrong? Hell, vinyl would be a better but still a crap idea. Don’t want anything there that might trap moisture.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 01-24-2023, 08:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1521 (permalink)
Your assuming it gets driven
Old 01-24-2023, 08:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1522 (permalink)
lateapex911's Avatar
Yea, I was thinking that it was the seat material when I saw the pic, then thought "Naaaa, that's a bit risky" LOL.
hey nothing ventured, nothing gained.
A lot of interesting details on your car, is there a thread on it anywhere?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-24-2023, 08:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1523 (permalink)
Ayo Irpin, Ukraine!
70SATMan's Avatar
Yeah, there’s that, lol. Can you imagine the pull on that fabric with the lid down and the engine running? Probably why it already looks like a saggy diaper. That would do wonders getting sucked into the fan.
Old 01-25-2023, 06:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1524 (permalink)
cmpski's Avatar
Bahama Yellow 912 Super 190. In the last 12 months the car got coil overs and Elephant's GT3 front suspension. 95% of the hot rod stuff is under the skin.
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 01-25-2023, 09:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1525 (permalink)
Kind of Blue
MrBonus's Avatar
Originally Posted by cmpski View Post
That's an amazing build. I love the fuel injected Polo motor. Any idea what kind of power it puts out?
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 01-25-2023, 10:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1526 (permalink)
The 912 Super and the Pelican community deserve a thread on this build.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 01-25-2023, 10:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1527 (permalink)
cmpski's Avatar
Plenty of places to read about this car.
On these different sites the car is sneaking up on a million page views around the world.
This is probably one of the most documented 912's in the world.
This is the first 912 in the world to have this engine type installed 2010ish.
Chris Pomares
https://www.excellence-mag.com/issues/205/articles/less-is-more
reSee works - Home
A very cool article about Porsche almost putting a 4 cylinder 2CAM4 engine in the 912. The article is from the Netherlands. If you go to the back of the article you'll find an English translation.
http://www.reseeworks.com/netherlands-article.html
https://flatsixes.com/cars/for-sale-cars/polo-engined-912-911s-911/
https://www.912bbs.org/forum/threads/polo-4-cylinder-911-engine-and-1967-912-almost-done.37206/
https://www.early911sregistry.org/forums/showthread.php?69778-POLO-4-cylinder-911-engine-and-1967-912-almost-done
https://forums.pelicanparts.com/porsche-912-technical-forum/624688-polo-powered-4-cylinder-911-motor-912-a.html
https://forums.pelicanparts.com/porsche-912-technical-forum/624629-polo-engine-912-almost-done.html
www.reSeeWorks.com
Old 01-25-2023, 02:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1528 (permalink)
I knew I had read about this car before. A few cosmetic changes maybe since I read about it years ago. Love it.
Old 01-25-2023, 02:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1529 (permalink)
cmpski's Avatar
Thanks. More updates in the works. I'm looking forward to Rennsport.
www.reSeeWorks.com
Old 01-25-2023, 03:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1530 (permalink)
Phoenix's Avatar
Ok. I'll bite.
1973.5 911T Rebuilt from 2.4 to 2.9 liters now at:
215ft lbs @5,500 rpm / 245 hp @6,500 (at flywheel)
Bodywork and Engine Rebuild completed by Automobile Associates, Canton, CT
Engine:
• LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio
• LN Nickie Cylinders
• Existing 70.4 stroke
• DC 40 cam
• Pauter rods
• ARP rod bolts
• Port heads to 35mm Exhaust
• Port heads to 36mm Intake
• Valves ground and lapped
• PMO EFI system
• Clewett EFI management system
• Oil pump: rebuilt by Glenn Yee Motorsports
• 3.2 Carrera front oil cooler with factory brass lines
• High pressure fuel pump
• ARP head studs
• Engine Case machined by Ollie’s
o Time-cert threaded inserts/ case savers
o Shuffle pin case to reduce flex & movement
o Reinforcing weld @ #3 cylinder
o Oil squirters
• Aluminum pressure plate
• ARP flywheel bolts
• Narrowed air deflectors
• Club Sport engine mounts
Transmission/ Shift
• LSD transmission
• Shift bushings replaced
• NOS Aluminum pressure plate
• RSR lightweight steel flywheel
• Release bearing replaced
Suspension/ Wheels:
• Torsion bars: 21mm front / 27mm rear
• Turbo Tie-Rods
• Bump steer kit
• Ball joints replaced
• Elephant racing PolyBronze bushings front & rear
• Elephant racing strut brace
• Elephant racing front sealed monoballs
• Corner balanced & 4 wheel alignment
• Original 15x4.5” Fuchs rims
• Michelin 205 / 60 R15 Tire
Brakes:
• Front: Brembo AM Calipers on original T struts
• Rear: Original T brakes
• Stainless steel brake lines.
• Pedal cluster rebuild
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 01-26-2023, 06:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1531 (permalink)
Very Nice Oliver what color is it ? Also are you sure the rims are 15x4.5 not 15x6 ?
Old 01-26-2023, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1532 (permalink)
cmpski's Avatar
What color blue is your car. It's a beauty with all the good stuff in the build. I'm building a Ultra Blau blue 69 for a friend.
www.reSeeWorks.com
Old 01-26-2023, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1533 (permalink)
cmpski's Avatar
190ish hp and 170ish tq. It's hard to know for sure as there isn't an engine dyno set up in Denver for 911 type engines. So we have to use a chassis dynos at 5300 to 5900 feet elevation and guess what power would be at sea level. You have to add for elevation and add for rear wheel numbers. 10% to 15% for each depending who's opinion your using. So it's a guess.
There has been a lot learned about these engines in the last 10 years since my engine was built. Some POLO builders and Emory's engines are making 230 to 250 hp on engine dyno's at sea level. I looked into updating, but at this time I'll pass on spending the 30 to 40K to get to 230 hp. At 2100 pounds my car is a blast to drive. I can run with all stock long hoods from 2.0 to 2.4 liters and first gen Boxster's. This car was the first one and I think there are about 10 to 12 912 POLO's out there. Most in the US and Europe and one in Australia, and one somewhere in Asia.
I spent about half and hour with Emory's son in law at LUF8. We walked each other around our cars. He is young enough to be my grandson. Really nice guy. His car is stunning like anything that comes out of Emory's shop. It's been fun developing this car.
www.reSeeWorks.com
Old 01-26-2023, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1534 (permalink)
Caught that, too.
Old 01-26-2023, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1535 (permalink)
Kind of Blue
MrBonus's Avatar
190ish hp and 170ish tq. It's hard to know for sure as there isn't an engine dyno set up in Denver for 911 type engines. So we have to use a chassis dynos at 5300 to 5900 feet elevation and ques what power would be at sea level.
Amazing. I now remember reading the Excellence article about your car and I'm completely in love. You nailed all the details. It must be a riot to drive.
Old 01-26-2023, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1536 (permalink)
Phoenix's Avatar
The color is Dalmatian Blue aka Oxford Blue: paint code 329-9-2
You are correct... the rims are 6Jx15 (The 4.5x15's are the super rare early Fuchs rims)
...Oliver
Old 01-29-2023, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1537 (permalink)
nice to see another Dalmatian! here's mine (2.7 w/ RS P&C, early-S cam, webers)
Old 01-29-2023, 04:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1538 (permalink)
Had posted earlier in this thread - car has been completed and now has >4K miles on it. Love it!
2,133lbs, 2.5MFI, 217hp and 201tq at the wheels (estimated 250hp and 232tq at the crank with 15% drivetrain). Gotta love narrow body, small displacement hotrods!
Old 02-05-2023, 11:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1539 (permalink)
Kind of Blue
MrBonus's Avatar
2,133lbs, 2.5MFI, 250hp and 232tq at the crank; 217hp and 201tq at the wheels. Gotta love narrow body, small displacement hotrods!
I really enjoy your content on Instagram. Amazing machine!
Old 02-05-2023, 11:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1540 (permalink)
