Chain fence eating turbo
Hoy crap!
I can't believe this has happened to so many people. Mine have always been tight.....maybe because I always put the "oil field torque" on them.....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
AutoBahned
the metal faces will retain the grease only if they are are nice and flat - which they should be BTW - safety wire will not maintain tension on the bolts nor will it keep the faces of the CV joint on the mating part - it only prevents the bolt form being backed out all the way the bolt will be snapped in half even when safety wired so, I don't see any reason for safety wire... |
Ok Stupid question time,
Would Lock Tite world or help? |
As long as they are torqued to specs.
Removing them after Loctite will have you cussin'
I have the same year, and I have seen contradictory info on this board. Some say the 82 did NOT have the schnorr washers and plates from the factory (the parts diagrams I have seen support this) and some swear they did.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Tippy
been doing alot of cussin on this fix, any idea what the tourqe specs are? thanks Rob |
Schleprock
The washers are good insurance, regardless of whether they are factory spec for whatever year you have, or not. The key is to make sure the contact surface between the screw head and moon plate are clean & dry. After installing and test-driving it's always a good idea to check for tightness again. The M8 CV screws are known to come loose.
The M10 like Tippy has rarely come loose. I've tracked my '87 for years and every time I check the M10 screws, not one is ever loose. Not even slightly. However on my '79 racecar, every once in a while i'll see the paint safety marks slightly misaligned. It's a good way to watch your screws w/out having to torque check them all. This season the '79 gets a new supply of screws with moon plates and serrated washers. BTW the bell crank is part number 911.423.017.01 Pelican Parts - Automotive Parts and Accessories - Porsche & BMW The torque spec for the screws is 30 ft-lb for the M8 screws and 60 ft-lb for the M10 screws.
Kevin L '86 Carrera "Larry" |
KTL thanks for the info, i have the lock washers , new gaskets, and will try the safety marks.
thanks for the part number on the bell crank |
MBruns for President
I put the stage 8 locking bolts on my car with the early transmission (only four per side)
Seems like good insurance.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Cheap insurance
I ordered a set of stage 8 locking bolts cuz the last thing I want to see is this kinda carnage when I grab a big hand full of second gear
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Pic of Stage 8 locking bolts
Here's a pic of the Stage 8s
Got you all beat on close calls. Saw a bolt in the driveway and said to my self, I know where that goes. Sure enough the remaining ones were loose. Reinstalled with new washers and a dab of locktite and so far so good a couple years later.
Chris 73 911 E |
Has anybody used epoxy in the threads? Bolts could be removed then with heat applied to the bolts with a torch. Seems to be easier for removal than red Locktite. Blue Locktite is probably too weak. Is that even thinkable for those CV bolts. I have done it in other applications but I don't know whether heating those bolts is practical.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
So far so good on the Lock Tite. I cleaned the threads and bolts as much as possible. Applied the lock tite to the bolt and the CV threads and tried to avoid getting grease on them.
my bolts protruce a couple MM's from the back of the CV Joint. I put a drop of lock Tite on the end of the bolt as well. Just another layer of possible protection and I check them every time I look under there. Chris 73 911 E |
just installed my new STAGE 8 LOCKING BOLTS after similar CV carnage at Sebring in my 944 S2 race car. Stage 8 reports zero failures ever. Anyone having good results with these bolts ??
![]() Same old story as others on this thread; grease flung everywhere, a few bolts backed out without damaging allowing to go back together to limp home, and the throttle linkage got a nice lashing.....
AutoBahned
the problem does not need to be solved with epoxy or Loctite or expensive locking fasteners
just [1] get all threads clean with brake cleaner, both female and male [2] use moon plates [3] use NEW Schnorr washers [4] inspect the cap screws (bolts) carefully - both threads and the indent for the Allen socket (aka, wrenching fixture) & see [1] above [5] torque properly [6] check the torque later this has been posted innumerable times here by Grady, Jim Sims, and on the CV thread that rececale (sp?) started, but it does not seem to have sunk in - maybe those threads should be made stickies and Emailed to everyone who joins Pelican with their authorization Email |
I have the Nord-Locks on mine and have been really happy with them. I can see how safety wire or stage 8s are another step above that, but that's also getting a lot fussier for install.
The torque needed to unlock the Nord-Locks and take the bolts out seems to be about 2-3x the amount you torque them down with, they hold really well. They are also reusable, and available locally more easily than Schnoors. ![]() Once the ramps are locked together, they have to be spread apart to loosen at a different rate than the bolt pitch, which is what makes them hold tighter than a teeth only solution. One thing to note if you think of switching is that they are thicker because of having two halves, and may require longer bolts. (Good to switch to new ones anyway)
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P Last edited by MysticLlama; 08-18-2012 at 01:11 PM.. |
RWebb - I forget, but do the cupped side of the Schnorr washers face the moon plates or the allen head bolt ??
Robert Williams 70' 911T |
AutoBahned
Clean all grease out of the threads. Concave side of Schnorr washer faces away from cap screw head, toward the moon plate.
parts for mine: Bolts, M10x48, 12.9 strength; 55 mm long overall; 48 mm from end to base of head; p/n 900-067-128-01; 4 bolts per side of each axle = 16 total 16 Schnorr lock washers, p/n 999.523.103.01 8 moon plates, p/n 911-332-191-00-M100 4 paper gaskets, p/n 901-332-297-00 you only need new washers and gaskets each time if the rest looks ok, as per above |
