supsension pan rebuild
Here's the suspension pan rebuild I started last week:
This project began as replacing the o-rings on my ac hoses:
Now it has grown to include:
suspension pan
ball joints
a-arm bushings
struts
tie rod ends
etc.
86 911 coupe
2001 VW TDI
Old 09-17-2005, 05:48 PM
more pics
86 911 coupe
2001 VW TDI
Old 09-17-2005, 05:51 PM
techweenie's Avatar
If you want to repair that inner sheetmetal at the top of the front wheelwell, I have a recently cut off piece for it.
PM me.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 09-17-2005, 05:56 PM
where did you get your suspension parts from?
Old 09-17-2005, 09:34 PM
Matt_C's Avatar
Looks like the fender supports are rusted also....hard to tell in the pics. If you are planning to replace, please post some pics.
Thanks!
1975 911S (under construction)
Go Red Devils!
Old 09-17-2005, 09:42 PM
c911s :
I got the replacement suspension pan and fuel tank support from MAMS, they appear to be good quality.
Matt_c
The fender support is rusted pretty bad. I am going to probably fix this either by buying one or fabricating one myself as it is a pretty small area. This area bothers me because it is very close to the upper strut mount and probably see's some pretty high stress's so I want to take my time and do it right.
I'll post some more pictures as I progress.
86 911 coupe
2001 VW TDI
Old 09-18-2005, 09:22 AM
ryanmt,
I just did this my 80 SC if you care to look at my pictures. It turned out pretty good for my first time doing it.
http://winston1.home.mchsi.com/
Terry
1981 SC
Old 09-18-2005, 06:21 PM
Terry
That's a really good website. How did you remove the undercoating? I've tried using the grinder and it chokes me out really quick. Also, did you remove this part in the picture? I was considering cutting the pan out along the 90 degree bend in the front (see picture 2). I was going to create a lap joint, although it is not stock intend my intuition tells me it will be alright.
86 911 coupe
2001 VW TDI
Old 09-20-2005, 05:24 PM
cassidyp's Avatar
Is all that rust on the 86' listed under your id? Seems bad for a newer car. Sorry to see that. I also have had the unfortunate pleasure of doing some major work in that same area. Take your time and keep up the good work.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 09-20-2005, 05:43 PM
ryanmt,
Sorry it took so long to get back to you.
I used a 4" grinder with a course wire wheel. Works real well. The undercoating really goes flying. Yes, I removed the piece missing. I used a sawzall to remove most of it, then drilled out all of the spot welds and very slowly removed the pan. I butt welded my joint toward the back. Why? I don't know, but it turned out well.
Terry
1981 SC
Old 09-26-2005, 03:55 PM
