lifting points on 911sc
Where is the best place to place hyd jack or hoist pads on a 911sc
Thanks Dan |
Under the engine, just a few inches behind the tran/engine mating point, and only to lift it up in order to place jack stands under the torsion bar covers.
There are access ports on either side of the car (square, covered by plastic) that you can insert a jack plate and use the jack on the plate. Other than that, I also used a 1 inch thick of hard wood over the jack, place the whole thing under the body at a nice stout place in front of the suspension for jacking up the car.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
There have been pictures posted of this, have you done a search?
yes but cant seem to find the right search terms . I have tried jacking points, lifting points ,jscking up 911 etc.
Thanks Dan |
I just did a search on "jack and point"
and got these 2 #1 #2 "jack" gives #1 #2 there are a lot more
Thanks a lot .
Dan Johnson |
Thread Tools | |
Rate This Thread | |
