Irrationally exuberant
Sorry about your beautiful car but glad you're OK.
BTDT. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
PRO Motorsports
Yes, that's him. I heard that story years ago. He's got some even better ones too!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Me like track days
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Black and Blue
Cool under pressure indeed! i would have soiled myself
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Anyway, I'm glad the damage was superficial...although I kinda wonder what BBIII would be like (did I say that out loud?). |
Jack,
If you are going to needlessly thrash my dream car like that; I'd just as soon you give me the keys and call it done!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Tyson, I figured it must be him. Here's another one:
http://www.anecdotage.com/index.php?aid=17095 So, Jack may have had a brush with the wall, but we've all had a brush with fame
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
Classic Pose! But yes that accident was very well documented. Glad you're fine.
1982 RoW 3.0 911 1999 996 |
Me like track days
Sideline Sports is a great outfit - he took these pics of me in Portland in 2004:
I'm not an engineer, but I agree re the possibility that it's dust - or a mix of duut & smoke. The ehat would push it out (expanding pressure from heating the air, PV = nrT) just as Isl. says.
More tothe point, I'm glad you're ok, and that car is not too badly damaged. The pics make it expecially helpful & instructive to us all.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
dave 1973,5 |
For the damage there is always Mastercard
but this is Priceless glad to hear that you're ok
Jack, I'm glad you came out OK, and the car should be OK (that'll buff right out!)
I'm just surprised that one of those tires didn't come in the window and give you a kiss!
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Fletch truly defines grace under pressure.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Jack,
May I add a bit of advice? 1) As you said, you were coming in way too hot (this will come with time), so I agree pads were probably not your enemy in this situation. Pads should be checked prior to every event. If the rear pads were thinner than the front, they'll come up to temp quicker, thus bite harder, and vise versa. I don't know why you would be using two different compounds, probably something that can be avoided with proper use and adjustment of a prop. valve to avoid the possibility of this happening again. 2) From the mini-movie it looks like you were sliding quite a bit, but not one hint of steering correction or brake modulation. I know it’s scary to see a wall charging at you (you look like an ostrich with its head in the sand), but it very well could have been saved with proper inputs, possibly from even before the pictorial started. 3) You KNEW of a mechanical issue and still chose to run, putting you AND others out there with you in jeopardy. Not smart. You’re not racing, just silly roundy-round track time……..miss a session and resolve your issue FIRST. I am glad that all turned out well, so just let this be a (expensive) lesson. Let’s keep it safe out there, for you, and your trackmates.
Bob Finkle 1982 Carrera |
Amazing sequence of pics... but yes, take part of that $300,000 per script and buy a proper helmet! We need that famous mug intact around here!
'95 993 C4 Cabriolet Bunch of motorcycles |
Jack,
Glad you were not hurt. Now BBII wears the mark of experience.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Bird. It's the word...
Tell us more of your fantastic insight Bob. Tell us about your vast track experience, car control skills, titles perhaps? (I don't know, maybe you're well qualified to judge... )
You also seem to have a less than latent dislike for all things Jack, based on previous threads... The whole point is that the track is the most appropriate place to test, try, experiment with a car. But thanks, next time I have a track incident, I'll shoot you the details and you can debrief me
John Forcier Current: 68L 2.0 Hotrod - build underway Last edited by Fishcop; 12-14-2005 at 05:35 PM.. |
Also glad you are not hurt.
I think you look like one of my dogs getting her chest rubbed. Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I once lowsided my motorcycle on a wet corner. Now I'm wishing I had pics so Bob could evaluate the incident and tell me what I did wrong and how I could have saved it.
You know, the last thing anybody wants to hear after something like this is some know it all telling you what you did wrong. How annoying!!
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
