different profiles of 8" wheels
Hi,
I am contemplating the move to 7" /8" wheels from the existing 6"/7" x 16. I've been shopping,....casually, and it seems like there are 2 different profiles, especially noticeable on the rears,...the 8"s. Some appear to have a long angled section, and some appear to be more stepped. Is this relative to year manufactured?
Also, any comments on those of you that have moved to 15" down from 16"s, same diameter? It is appealing to me as it seems it could reduce unsprung weight and help improve acceleration,...assuming I stay with the same aspect ratio. I know I will screw up the speedo etc,..don't really care about that.
THANKS for your comments.
Rich
1988 911 coupe
1970 911t project
2012 Golf R
Old 01-03-2006, 08:52 AM
AES AES is offline
check here for lots of great Fuchs info
http://members.rennlist.com/1976c38/index.html
Old 01-03-2006, 09:15 AM
Todd Simpson's Avatar
Rich-Can you post a pic of the wheels you've seen that look different? I'm not aware of any 911 16x8's that had a different appearance.
There are some custom made wheels out there that use fuchs centers and aftermarket barrels. Those often have a stepped appearance.
Old 01-03-2006, 01:08 PM
SC-targa's Avatar
He's probably looking at 951 and 911 offsets.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 01-03-2006, 01:15 PM
Bill Verburg's Avatar
Jerry Kroeger
That would be my guess as well
Bill Verburg
Old 01-03-2006, 01:19 PM
Registered Cruiser
jorian's Avatar
There are no different "profiles" as far as I know. As others have mentioned the 8" fuchs that have the 951 offsets were spec'd on the 944 and differ from the 8" spec'd on the 911 to accomadate caliper clearance issues. To use 8's on the front of your 911 you have to use the 951 offset.
The 15" wheel is something I would consider if I were doing alot of Auto-X. I don't think they look nearly as nice as a set of 16's though.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 01-03-2006, 01:40 PM
the 911 8 does have ~.5" extra caliper clearance, but that isn't immediately apparant. The o/s differs from the 911 8 as well +23.3mm for the 944/951 and +10.6mm for the 911.
The most obvious difference(to me) is the counter sunk lugs on the 944/951 8, also used on the 9 but not on the 911 8.
There were no 8x15s w/ an o/s other than the 911 ET of 10.6
Bill Verburg
Old 01-03-2006, 01:48 PM
Bye, Bye.
Scooter's Avatar
951 16 x 8 Profile:
911 16 x 8 Profile:
Elvis has left the building.
Old 01-03-2006, 03:07 PM
THANKS to all!!! I guess the wheels I have seen for sale recently are the 951 wheels. They were offered as fitting 911/930 and I guess they will fit, but have a different offsett.
THANKS again for your patience with us less knowledgable
1988 911 coupe
1970 911t project
2012 Golf R
Old 01-04-2006, 06:01 AM
Wavey's Avatar
There are indeed two different profiles for the 16X8 rear wheels (not the 951 front wheels). I have a pair on my Carrera right now:
I think these have two slightly different part numbers - heading out the door right now but I'll look it up later. These wheels have identical backspacing and offset, but the profile is different on the backside of the spokes. Left side of the photo is the inside of the wheels. They look identical on the outside.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 01-04-2006, 06:21 AM
don911's Avatar
That pic looks familiar. There is a post on pelican on the slight differences between the two p/n of the 911-8's.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 01-04-2006, 11:08 AM
If you followed the link AES posted you would find the 944/951 +23.3mm Et wheels can be used on the front of a 911 or w/ spacers on the back of a 911
The 911 +10.6mm ET wheels on the other hand can only be used on the back of an SC/Carrera flared 911 or the front of a 930 flared 911.
The fit isn't always the easiest or best though.
Bill Verburg
Old 01-04-2006, 12:23 PM
Wavey's Avatar
As it should, Don!
I found my notes from when I bought these wheels from Don.
One of the above is P/N 911 361 020 45 (original 8X16 Turbo fitment)
The other one is P/N 911 362 117 00 (factory later superceded the first number to this number).
But I don't know which of the above is which. However they both have the same offset (10.6mm) and backspacing (120mm) so they function exactly the same. The only other difference I can recall is that one had square edges on the valve stem hole and the other one had a chamfer.
Old 01-04-2006, 12:27 PM
