you can get the slats from NR auto. i got my steel rear fender vents and slats and box rockers from them.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Now accepting US $ at par
Don't do it!! The unboxed rockers and open vents look so cool!
He has to, the holes for the slats are already drilled in the vents
Nothing better than a slant
If your not raving. Headlights require A new amount of patience most Have yet to achieve . Just keep tellin the car I'm gonna win so you might as well Just do it A slant nose Is like a business It needs to be managed . |
I think there were at least four different after-market slantnose kits each with slightly different sized brake cooling vents. First check and see if your vent slats are metal (factory) or fiberglass. If fiberglass, I would trace the outline of one of them and fax it to some place like Better Bodies Motorsport who could identify which kit you have. It can be kind of a pain sourcing one of the after-market parts since most of them haven't been made for several years.
my kit had instructions for making them fit. you have to put wax paper over the curved section of the vent where the fins touch. then test fit them to make sure no material needs removed from the fins. then you put a thick coat of body filler on the part that touches the vent and screw it down. after the filler sets then you remove the slat, and clean it up and paint it and the curves will match perfectly.
Look at the arborvitae trees in the background of these before and after pics...
That's how long this car has been sitting..... lol ![]()
Update
Update
Update
Update
Update
Update
Update
Update
Update
Update
Update
