Hood Release
I need help. I broke the hood release lever, because i tried to open the hood and yanked it to hard.
Is there another way to open the hood? ThanX!! |
I think there is. Let me see if I can find a source.
Pat
10 Ford Raptor 86 930 |
Hmm,
In my Haynes there is a procedure to cut an access hole to release a stuck trunk lid. I am somewhat concerned though since, by design, the hood latches are supposed to release when you pull the handle or a cable breaks, If the cable brakes, the spring takes out the remainder of the slack to release the hood. I recall a number of posts about stuck hoods and a search using terms like: stuck hood latch should turn them up. As I recall, pushing and applying some force sideways sometimes works. Going down a rough road may also jar it loose. Good luck!
I found it, send me your email and I'll send it to you. It involves removing the bumber and drilling a hole.
Pat
Interesting links found with the search terms stuck hood.
http://forums.pelicanparts.com/showthread.php?threadid=269475&highlight=stuck+hood http://forums.pelicanparts.com/showthread.php?threadid=238530&highlight=stuck+hood http://forums.pelicanparts.com/showthread.php?threadid=219877&highlight=stuck+hood There are many more....
I can't get it to post, the file is too large and I don't know how to reduce the file size.
Pat
Before cutting holes, try this.....Push down and over to one side or the other as hard as you can.....I've done it before and it works...
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
I guess we lost him.
Thanx I will try all your ideas
1973 911T Slantnose GSXR 600 1995 740I 1992 SC400 1992 E36(M3) |
Green Skull 006
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
