Alum. Flywheel
The shop is installing a 5.5lb. alum. flywheel on my twin turbo
car. Just wondering what to expect, should be interesting.
"Never go faster than you can stop" 85 - 930 (750hp) Norwood motec 3.5 twin turbo |
no flywheel effect= fall on your face on take-off, unless you keep the Rs up and slip the clutch more.
3 restos WIP = psycho
That is just too light for the street.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Twin turbo 750 HP and you need more power on takeoff?
There's these things, I think they're called JATO units....
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
I'm going to ask more questions than answer:
1st gear ratio? Weight? Cam? Compression? Obviously you have enough HP, but if a stock 930 tranny and a grabby race clutch at a stock 2800 or so lbs.......Your going to slip clutch on take off. If your running a G50 or deeper gears in diff, if your running an organic clutch, if your lightened with an SC cam or better and 8.0+ compression, than your likely going to love it. It does make things easier to shift faster. I'm putting an Al flywheel and PP in mine with the turbo engine....I'm at 2300+,915, Evo cam, 8:1, EFI, Organic clutch.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Lets see a 5.5 pound aluminum flywheel probably has about 8mm cross section at the flange and 750 hp probably needs 3200 lbs of clamping pressure.
It is a good thing that the engine is behind you. regards |
This car is not a everyday driver, but it is a street car.
And everything you guys said is true. With the stock flywheel it would light the tires up out of hole. How much the flywheel helped with that I don't know. I'm running a Kennedy Alum. clutch with a six paddle solid metalic disc. This clutch bites hard and may be the tricky part. The car has a Motec so I can program another map if needed. I'm hoping to bring the rpm's up quicker. I am still running the 930 4 speed with a lower gear swap. Here's a few Pic's ![]() ![]()
Anthony @ Voitureltd Bayside WI. |
