Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Question To patch or to plug...
Just a quick question.
I found a screw in my right rear tire. Fortunately it is between the treads and not in the sidewall. It appears to be penetrating the tire in the straight down direction. My tires are ZR rated with less than 2K on them and I'm looking to preserve the as much strength as I can in the tire.
So should I have it patched from the inside (which is what I think I should do) or should I have it plugged?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-19-2006, 08:59 PM
Detached Member
Hugh R's Avatar
From the inside, always. Plugs and pull out.
Hugh
Old 06-19-2006, 09:05 PM
lateapex911's Avatar
Hmmmm..Ok, I'm not a tire manufacturer, (so i can't say absolutley) but I would take it to a good tire place that sells the tire brand you have. They might say "No", based on the ZR rating. Then it's up to you.
Inside repair is the prefered method of sealing it.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-19-2006, 09:22 PM
slodave's Avatar
Patch it - only way to go. I've had a number of Z rated tires patched. Plugs are only good if you are stuck in the middle of nowhere. I carry them when I go on long trips.
Old 06-19-2006, 09:26 PM
earlyapex's Avatar
Patch the tire and you will be fine.
Eric
1978 spec 911
1998 C2S
Old 06-19-2006, 09:33 PM
I thought plugging wasn't allowed anymore? At least that's what the tire guy told me here in CA a couple years ago.
I would patch anyways.
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/showthread.php?threadid=285064
Old 06-19-2006, 10:05 PM
Automotive Monomaniac
Emission's Avatar
Patch the tire from the inside.
If it can be easily patched (just a small puncture), it is still Z-rated.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-19-2006, 10:21 PM
randywebb's Avatar
This was on an old thread...
IIRC, a patch from the inside means you can still use the tire, but it loses its speed rating.
Plugs are not a well regarded repair technique any more...
Obviously the above might not hold true for a tiny pinhole or something, but...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-19-2006, 10:22 PM
Emission's Avatar
Whether or not the tire retains its speed rating varies from manufacturer to manufacturer. For liability reasons (they aren't going to inspect every flat tire), many just throw and in the towel and tell you to buy a brand-new tire.
Use your judgement. As long as the belt isn't cut (most nails and screws don't cut the belt), the tire is still perfect.
My best top speed run was done on two patched tires without any worries.
(Kinda related subject... can aircraft tires be patched? Does the FAA allow it?)
Old 06-19-2006, 10:29 PM
slodave's Avatar
Good question. I think that regardless of the FAA, everyone would rather just replace the tire than take a chance with a patched tire. My dad would never patch one of the tires on his plane.
Old 06-19-2006, 10:35 PM
Emission's Avatar
I've got a good friend who is chief mechanic for a Gulfstream IV. I have to ask him.
I can't imagine a 747-400 with a brand-new $$$ tire with a slow leak needs to toss it out... maybe?
Old 06-19-2006, 10:41 PM
slodave's Avatar
I'll ask my dad what he would do as well. I think he would replace it, but maybe not. I'd like to know as well.
Dave
EDIT: I do know that the tires on his plane do loose air from time to time and we will check pressure and fill if needed, but I don't know what he would do if the tire had a visible nail, staple, etc...
Old 06-19-2006, 10:52 PM
That was my point above. I imagine there are specific requirements for the tire to be a candidte for repair. Size of screw/hole, etc.
Also, tires are made of plies of belts..each one different and wrapped in different biases. If the screw went thru the carcass, it's thru something or somethings! Point being, speed ratings, like ZR have specific requirements, and you should be aware of what you'll own when it's repaired. Might not be a ZR tire, and that might be fine, but you need to know.
Old 06-19-2006, 11:10 PM
randywebb's Avatar
Y'all might enjoy this pic -- I couldn't decide whether to patch it or plug it...
Old 06-19-2006, 11:31 PM
slodave's Avatar
I think that'll buff right out!
Old 06-19-2006, 11:38 PM
Emission's Avatar
That will take TWO patches, then it's Z-rated again. The wheel may need some polish too.
Old 06-19-2006, 11:42 PM
Now in 993 land ...
aigel's Avatar
If you drive at ZR speeds you should replace the tire. It will be okay for 65 mph, but I doubt you drive that all the time, especially if you track the car.
Just do a back of the envelope calculation on how many G's a tire sees, spinning at ZR speeds. I certainly wouldn't want to spin a patch around like that.
In Germany, it is illegal to patch high speed tires.
Be safe, George
81 SC (sold)
Old 06-20-2006, 12:46 AM
charleskieffner's Avatar
we just replace them. man if your that cheap w/an aircraft tire............you deserve what you get! being cheap w/a porsche is one thing. being cheap w/a plane will get you dead real quick!
Old 06-20-2006, 05:22 AM
I just got done plugging a hole in my x5 tires. Maybe its the size, but these tires seem to pick up screws and nails everywhere. Most garages won't plug a tire, why? Because it would force them to not sell you a new one. I would not recommend them for track tires, but as far as being z or higher rated tires, how many actually drive a sustained 120mph for an hour or so? I've never had a plug fail. In fact, I've found tires with worn out nails in them that must of had a few 100 miles on them with no air loss. If it was me, I would plug it until you could get it to shop and then have them remove it and patch from the inside.
Old 06-20-2006, 06:34 AM
Senior Member
I fly them for a living and used to twist wrenches on them (A&P licensed mechanic) and patching is not allowed, period. Aint even discussed anywhere. Does not matter what the cost is, we just put a new one on the plane.
That said, there are not many things lying on runways to get stuck in tires. We have "FOD" (foreign object damage) trucks out with magnets that sweep the runways at many airports, keeping damage like this to a minimum.
Old 06-20-2006, 06:47 AM
