missing under load?
i started up my car after 2 months and warmed it up. the idle was bouncing around for a bit and then leveled off. whenn i took the car for a drive it drove fine but when i put my foot down to get the turbo going it started to studer and back down like it was starving for fuel. my car ran fine befor i parked it and i started it it everyonce in a wile. it seems like when i give it more gas it starts to starve. could it be the drop in temprature im at 40F right now and it was about 65F when i parked it. also when the car was started up the exhaust had a smell to it almost like it got to your eyes. could it be the fuel mixture. also i found a oil leak on one of the turbo line could this be a problem under load?
There's an outside chance the filter could be clogged. Could also be a fuel pump on the borderline. Check pressure and volume and compare with specs.
Perhaps a lack of boost could provide those same symptoms. Do you have the same symptoms at higher speeds (low load/no boost)? Sherwood |
is it runing........ruff??
at higher speeds with no boost its the same it runs fine. under boost/ load i have a problem
JP '76 911s Ice Green Metallic bone stock |
