Outboard CV/axle removal
Some time ago on this forum I dialogued with Early_S_Man and Grady Clay regarding a noise in my 88' Carrera's CV's (http://forums.pelicanparts.com/showthread.php?postid=2530625#post2530625). Well, I am now taking the plunge and tonight removed the inboard flange bolts and even though it seems obvious I cannot find any confirmation of how to remove the outboard piece. Forgive a silly question but do I have to remove that nasty looking huge nut on the end of the axle (doh!) to get the entire assembly out? I have read the CV threads here many times and this is alluded to in one thread where the need for a 3/4" drive and a piece of pipe are mentioned. Hey, that's my car at Pacific Raceways this summer!
Yup - you need either an industrial strength impact wrench or a 3/4" drive socket and cheater bar to muster the 350+ ft-lbs to get it off.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
3.4 Bigger is better
Colinsco
Yes the nut needs to come off and the lower shock bolt as well. Here are some pictures and how to do it. Carrera CV boot replacement
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
