just me
thanks a million!
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Member 911 Anonymous
just Pay it Forward(PIT), Brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
just me
I will for sure!
Always learning
Bell position
Hey Jim.
Don't know if u remember - I have the 3.2 in the 68. My throttle is sticky as well. how should the bell sit? Should the prongs basically point down to the ground? Mine is cocked on a 60degree angle at idle. The engine throttle link looks like it is to short. Thanks again Rolls |
Rolls,
Here is a shot from a side view of my Bell Housing Linkage. Hope this helps: Remember this is LHD side. ![]() Cheers, Jim Yes, I place a dust shield to the ball pivot to the pedal linkage, It is loose fitting with lube, I also noticed the rod would rattle against my trans mounts cross member.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-24-2011 at 09:33 AM.. |
Always learning
im surprised that the bell is rotated so far back. I thought it would be more clockwise to about 7:20. thanks for the headsup. hi ho, hi ho its adjust the screw we go.... im sick of tweaking. i just want to drive the thing!!!
you will soon brother, soon
Always learning
throttle bell
Hi again. Rehasing this thread - Just confirming that the bell arm pictured above is the correct way that it should sit? I.e. i thought it should be more like an upside down V rather than a V on its side as pictured.... Im about to adjust mine.
Oh my, your baby RHD, correct?
It should still be the same orientation if the Throttle Body arm in the engine bay is on the left had side. J
reviving this thread! I've changed the front and the rear Throttle Rod Bushings however I didn't change the middle one (yet).
Any instructions on how to remove the heater/e-brake on a '85? i've tried but didn't go 'all the way' as I didn't want to play with the e-brake cables |
I would mark the shifter plate prior to removal so it will go back in the same spot, carefully disconnect rod and or heater cable pivot assembly, move out of the way and you should see a metal bend tab to hold the bushing/s, use a mirror to locate it/them, open the coupler access and finish up the bushings, and that is pretty much it. As I recall, I think there is one near the front next to the pedals. It as been awhile since I did this but I kinda remember it.
Break a Leg M...911
thanks for the tip Draco! I think the bushing next to the pedals is this part no 90142325300:
https://www.pelicanparts.com/More_Info/90142325300.htm?pn=901-423-253-00-OEM - i'll have to change that one too concerning the 3 Throttle Rod Bushings (part no 90142322700) I changed the front one under the shift linkage and the one close to the coupler but i choked when I got to the one under the e-brake. I removed the seats and the 4 Allen screws and I think i just had to disconnect the rod of the heater but I didn't know how to remove the actual pull for the e-brake. i'll give it another try - thx |
Lube or No Lube on the Throttle Rod Bushings (901-423-227-00-OEM)?
When I replaced mine yesterday, I cleaned the rod, and the new Bushings were clean as well. I get a little noise when I thumped the rod in place. All guides in proper place and the rod through the Bushing. |
No Lube, disengage at the bell housing to see if you can repeat the noise
911SC '82
