Extension is good solution with 915 transmission. But G50 Hargett shifting hardware is located much lower. So if I understand correctly you not able to lift e-brake to get it "click". See the red arrow on Kepa's pic and compare it to pics from 915 shifter on page two.
911 -87 Marine Blue, 3.5 twin plugged, DC24, 22/23 sways, 22/29 bars, PB front and rear, G50 with Cup LSD, Heigo CS cage
911 -73 track project
Old 04-24-2012, 07:55 AM
tobluforu's Avatar
ooops, didn't realize it was for a G50, but when looking at that pic, what if you bought a used emg brake, cut it, welded in a right angle right where the end on the grip is at, added/welded an extension so when you pulled up it up it did not hit what the arrow is pointing at. Am I making any sense?
Old 04-24-2012, 08:46 AM
OffCamber00's Avatar
Just adjust all the slack out of the e-brake and put the shifter into reverse - it will move the joint over enough for you to get a couple of clicks. Not the most optimum solution but it will work well enough for you to pass inspection.
Mat P
1988 911 Carrera
Old 04-24-2012, 08:54 AM
Actually i tried this today and with a small fix, i think it will work just thru inspection...
C 3.2 -89 25th years special edition *RUF-Look*
Old 04-24-2012, 12:27 PM
Curious as to how folks have made out with their G50 Hargett esp. with the Ebrake...
Prior ; '83 SC, '86 911, '87 951, '91 C2, '96 993, '06 Cayman S, '88 Carrera. Current track rat; '12 Cayman R
Old 09-25-2012, 03:38 PM
nardo911's Avatar
Send a message via ICQ to nardo911 Send a message via MSN to nardo911 Send a message via Skype™ to nardo911
I have a 915 on my Harget is really very good i am very happy
for the handbrake I cancel service and I will build a hydrolic handbrake on the side
bernard
Old 09-27-2012, 08:46 AM
