Banned
Is something missing here?
I got this back from a shop a couple weeks ago and was checking under the lid today, it looks like something, a cover, is missing but I can't remember if there was something there and if so, what it looked like. I just looks like it should have been covered and I don't remember seeing it so open. I can't find a picture in any of my book that shows that area, so, what do you think?
Old 06-30-2007, 01:07 PM
slodave's Avatar
There is a plastic cover that goes over that area.
Old 06-30-2007, 01:11 PM
jbrand540's Avatar
Not sure what year you have 84-89? But here is a link to a diagram that shows the cover for 87-89. Part number is oem-91161010504
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/902-00-Frame3.htm
'89 Carrera Cabrio
'01 Audi A6 2.7t
'01 BMW 540i
'06 Dodge Ram 2500 Diesel
Old 06-30-2007, 01:21 PM
Why am I not surprised that the shop left something off?
Old 06-30-2007, 01:31 PM
Banned
Thanks, it is an 89 and I will go in Monday and check on it, the area just looked so different and I wanted to be sure before I go back.
Old 06-30-2007, 01:40 PM
rnln's Avatar
Not sure if your car has ie before you bring it in but there should be a black plastic cover there to cover the whole area (big). The little square red bracket you see in your pic is where the top bolt mount to.
Fat butt 911, 1987
Old 06-30-2007, 03:51 PM
shbop's Avatar
Be careful to avoid grounding the fuses, until you get the cover back on.
Jon
Old 06-30-2007, 07:08 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
You can tell that the cover hasn't been missing for long due to how clean that area is.
BTW what kind of work was the shop doing that they needed to take the cover off in the first place?
-MAtt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-30-2007, 07:43 PM
Banned
-MAtt
The idle would surge, go up to 2500 and stay, I could flip the throttle and sometimes it would drop, sometimes not. Sometimes it would die at a stop, it is missing the cover but the idle stays constant. So, I don't know enough to know why the cover is off.
Old 06-30-2007, 08:26 PM
Band.
It's likely they took the cover off to get some power for a timing light or engine analyzer.
1983 SC Coupe
2020 Macan Turbo
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-30-2007, 08:37 PM
jbrand540's Avatar
They would have probably had to jumper the ICV in order to test/diagnose/adjust the idle.
The black rubber circular port in the metal panel right in front of the ignition coil is what they would have been accessing.
Makes you worry though if they missed something that obvious what else may they have forgotten.
'89 Carrera Cabrio
'01 Audi A6 2.7t
'01 BMW 540i
rnln's Avatar
BeyGon,
I hope you don't might I use your pic to ask everyone a question abou the top fuse. This pic look the same as my 87/88 but mine doesn't have the top fuse.
Anyone know what it's for?
Fat butt 911, 1987
Old 06-30-2007, 10:16 PM
Band.
Rear window defogger and "rear wiper return"?
1983 SC Coupe
2020 Macan Turbo
1963 BMW R60/2
1972 Triumph Tiger
Old 06-30-2007, 10:21 PM
rnln's Avatar
Thanks Gogar,
Make sense, since my car is a cab.
Fat butt 911, 1987
Old 07-01-2007, 01:17 AM
Somatic Negative Optimist
Gunter's Avatar
Make sure you'll also get the 2 wing bolts along with the cover.
Don't let them jamm sheetmetal screws in there!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-01-2007, 08:27 AM
