seat belt mod question
Gentlemen and/or Ladies,
I have a ’69 911T, and just did a seat belt mod by way of upgrading to later model Porsche recoiling belts. The recoiling mechanism bolted on nicely to an already existing nut which was welded to the body. Strange to find a nut there since I’ve never heard of optional recoiling seat belts on a 1969 model car. In any case, my stock interior trim piece (recoiling seat belt cover) is no longer appropriate since its shape does not accommodate a recoiling seatbelt mechanism. Later model Porsches (1974 and beyond) have the recoiling mechanism mounted in different place to mine so a trim piece from that era won’t work. I’ve been told that Porsche made a “box” that bolted on to an early model trim piece like mine which covered the recoiling mechanism. Apparently, this box was available on ’72 or ’73 model year cars when the recoiling belts became optional. I’ve yet to seen one. Question(s): Does such a thing exist, and where can I get two? If they are rare, then I’m open to other suggestions. Thanks, jeffy
1969 Porsche 911T - Tangerine |
I installed newer style, retractable seatbelts in my '70. I believe that I too used the existing threaded mounting hole in the rear quarter side. I also used the newer style side molding with the slot fo the seat belt. It's a bit forward and the belt rubs slightly but it works.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
AutoBahned
my '73.5 has rollup belts but no box -- unless I don't understand what you mean by box...
Thanks for the pic, Sergio. I tried one of those newer moldings (like the one you have pictured) and the belt slot was not nearly close enough to the retractable jobbie. No way it will work. (I don't have a picture handy). This must mean your nut is welded in a different place to mine.
So I guess you've never heard of the add-on "box" I refered to?
RWebb,
The box, I'm told, was sonething that screwed onto the existing seat belt molding for '72 and '73 cars if the buyer opted for retractable belts. Maybe '73.5 cars had something a little different. Obvioulsy, I have delved into the obscure. Thanks for the reply.
Jeff69911t,
Here's a pic of the box on a 72. Sorry it's not a complete pic, but the boxes do exist.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
AutoBahned
Interesting - here is my '73.5 car. It had about 6 PO's so dunno if it is stock...
![]() - note the rear seats are removed unlike the prev. car Last edited by RWebb; 11-26-2007 at 06:19 PM.. |
My 72 Targa has retractables. I had them replaced with oem stuff built to current safety standards at a company called performance engineered parts in Los Osos, CA. At that time, the guy there (gowesty.com) who does the Porsche seat belts indicated he had done many updates for earlier cars and that he had a good looking, simple solution. You might give him a shout.
David 1972 911T/S MFI Survivor |
ossiblue and RWebb, you guys rule. Your pics illustrate exactly what I'm talking about. They are rare, but at least I now know what I"m looking for. And david, I'll also follow up on your lead. Thanks again guys! Jeffy
AutoBahned
I actually like the look of Sergio's install. One you cut the slot back a bit and shift the slotted cover back. There might be a small cut showing forward of that. If so, I bet it cold be filled with that vinyl repair stuff.
Anyway, Good Luck! |
That's exactly what I did on my '73. It looks exactly like Sergio's.
I think I need to do that on my '72. It have the no retractable seat belts.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Sorry Jeff - I knew they didn't have the boxes. He just pointed out to me that they had a nice, simple solution to the problem of retractibles for the earlier early cars that looked good and that customers seemed to like. And I've seldom met a nicer guy to work with - I think his name may have been Travis.
But don't bring your wallet to gowesty if you're a bus fan - they have too many cool toys there! To wit: ![]() ![]() ![]()
No apologies necessary, David. I just wanted to report on my gowesty findings. They sell other stuff like the seat belts and brackets which are worth checking out. You’re right, the guy is super nice. And his name is Trampas. I love our little Pelican community. Jeffy
For those of you who might be interested, here are pics of the seat belt receiver and how I mounted the belts to the b-post and seats.
I bought the complete belt package from a fellow Pelicanite and the receiver mounting hardware was cut out of a wreck at EASY. I drilled a pair of holes in the receiver mounting hardware and mounted it far enough back so that I could reach through the tunnel hatch and secure the hardware with bolts and nylock nuts. ![]() ![]()
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) Last edited by PCA7GGR; 11-28-2007 at 10:14 AM.. |
Here's a pic of the belt mounted on the Recaro rail.
Hey Rwebb thats exactly how my early 73 looks. So its stock. I had a harness bar in the car and 4 point belts so I'm in the process of switching back to regular belts.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
AutoBahned
I wonder if that receiver mounting is strong enough for an accident? You might put a plate behind it and use high strength or really fat bolts. I'd feel better if it was all welded up...
Jeff - one more point. If you are restoring the car, I believe Trampas is/has designed the labels needed for the "receiver" on your seat belts. "Press"
