oak oak is offline
How to test for vac. leak ???
On a SC, what would be the best way to test for a vacuum leak. Flood engine parts with propane, acetylene, or carb. cleaner? Pressurize the intake with air and then spray everything down with soapy water? Or - I have heard of using dry ice under pressure????
I don't have access to a fog machine.
Old 11-29-2007, 11:46 AM
1984-911 M491
Trog's Avatar
The best way... smoke test.
Old 11-29-2007, 11:47 AM
chris57's Avatar
Use propane and listen for rpm changes will be your safest way with out a smoke machine. carb spray can be dangerous (fire), though I have been told that maybe berrymans makes a carb spray that is not flammable.
1985 911 "turbo look"
2008 Foose F150 (free truck)
2002 Mercedes Benz S55
Old 11-29-2007, 11:49 AM
Autodidactic user
David E. Clark's Avatar
Here's the best guide I know: Engine Vacuum Leaks By Larry Carley. Scroll about half-way through the article until you get to a section called: "ENGINE VACUUM LEAK DETECTION."
You might want to bookmark this page: Carley Library of Automotive Repair Articles. The author has written a lot of very useful stuff!
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 11-29-2007, 12:14 PM
SCWDP911's Avatar
sub'd
Shane
- 1984 928S
Old 11-29-2007, 12:25 PM
