Autodidactic user
David E. Clark's Avatar
Mechanical fuel injection resource index
I've decided to try to update and make the MFI Message Board Index easier to use until the Pelican wiki is functioning. The separate posts are so that I have room to add additional links later. Please let me know what you think about this new format and if you find any links that do not work. Thanks.
Last update: 14 May 2009
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-06-2009, 09:34 AM
Autodidactic user
MECHANICAL FUEL INJECTION RESOURCE INDEX
Adjusting Idle:
Adjusting MFI Engine Idle, Factory Workshop Manual, 1972 Supplement, volume 2, pages 3.1 1/2 - 3.1 1/3. Posted in Ultimate MFI Resources Thread, post # 7.
MFI idle on max, still lean on idle? Setting MFI idle, rich/lean running, importance of working thermostat.
Adjusting MFI pump:
Adjustments to the MFI pump for timing and mixture by Leslie Rice. Includes advice on making adjustments to the MFI pump, timing the MFI pump and inspecting the MFI timing belt. Also describes useful tools.
Adjusting Fuel Injection Pump with Emission Tester, Factory Workshop Manual, 1972 Supplement, volume 2, page 3.1 1/1. Posted in Ultimate MFI Resources Thread, posts # 11 & 13.
MFI Open Heart Surgery II - The Fuel Pump. Thread detailing rebuilding the very expensive MFI fuel pump. Great pictures.
Breaking in an MFI motor:
Motor break in with MFI. Step by step guide to breaking in a new or rebuilt MFI motor.
Check Measure Adjust:
Mechanical Fuel Injection, Check Measure Adjust. The Bible! 47 pages of must have material for any MFI owner
Page 4: Characteristic Features and Variations
Page 8: Tools and Auxiliary Aids
TUNING OPERATIONS
Page 10: Basic Points
Page 11: Check Loss of Compression
Page 12: Spark Plugs
Page 13: Dwell Angle and Ignition Timing
Page 16: Ignition Timing End of Delivery Stroke
Page 17: Correlation
Page 22: Synchronizing Throttle Valves
MEASURING EXHAUST EMISSION
Page 24: Prerequisites
Page 25: Part Load Measure
Page 31: Idling-Speed Measurement
Page 33: General Hints for Measuring on Dynamometer
Page 35: Troubleshooting
Page 41: Putting Injection Pumps into Operation after Storage
Page 43: Bosch Injection Pumps Type 911
Page 44: CO Values of the 2.0 Liter Engine
Page 45: CO Values of the 2.2 Liter Engine
Page 46: CO Values of the 2.4 Liter Engine
Page 47: Product Information
Differences in Check, Measure Adjust Manuals.
Finally getting around to CMA on my MFI. Long thread discussing the value of thoroughly following CMA on MFI vehicles. Look especially at threads by Grady Clay and John Cramer.
Cold start:
Cold Start Solenoid problems. Discusses cold start solenoid problems on pre-1970 MFI 911's.
MFI, 1972 warm-up issues (combined). Long thread which also contains lots of information about the MFI thermostat, miscellaneous cold start issues and having patience with the MFI system.
MFI Cold Start Problems by Robert C. Spindel. Explains the operation of the cold start solenoid.
Cold Start-up routine MFI. This thread discusses the start-up routine for MFI cars. “With everything working properly the best sequence is: Pull on the properly adjusted hand throttle. Turn the key to “on” (not “crank”) for 1-3 seconds to clear any bubbles from the fuel circuit. Crank to start. When it fires give a quick rap to 3-4000 or so to clear out unburned fuel from the cold start. Drive it immediately.”
Correlation:
Using Protractors for correlation discusses how to use MFI protractors for correlation and why following CMA is so important.
MFI air/fuel set-up. Setting the air fuel mixture as part of the correlation process. Documents showing that protractors are not absolutely necessary for final correlation.
Diagrams:
MFI diagrams and cutaways. Great illustrations including exploding diagrams in case you ever take the thing apart!
BOSCH MECHANICAL FUEL INJECTION PUMP ASSEMBLY SECTION
BOSCH MECHANICAL FUEL INJECTION REGULATOR SECTION
THROTTLE BODY LINKAGES
THERMOSTAT DIAGRAM
FUEL SYSTEM DIAGRAM
MFI SYSTEM DIAGRAM
MFI FILTER DIAGRAM
1969 MFI SYSTEM EXPLODING DIAGRAM
EMISSIONS SYSTEM tank ventilation-MFI diagrams
EXPLODING DIAGRAMS FOR 1972-1973 MFI SYSTEM. Posted in Ultimate MFI Resources Thread, post # 25.
RPM Transducer/Speed Switch for Bosch MFI diagram. Posted in Ultimate MFI Resources Thread, post # 3.
ELECTRICAL WIRING DIAGRAM FOR EARLY MFI CARS. These electrical wiring diagrams were converted by Derek Murray. Electrical diagrams for the early cars are also posted on the Rennlist website here.
Electrical:
MFI electrical systems. Discussion about MFI electrical systems with a lot of very useful diagrams and schematics. More MFI electrical information can be found in ELECTRICAL WIRING DIAGRAM FOR EARLY MFI CARS. These electrical wiring diagrams were converted by Derek Murray. Electrical diagrams for the early cars are also posted on the Rennlist website here.
MFI speed switch and fuel shut-off solenoid . Describes how the MFI speed switch and fuel shut-off solenoid work and has electrical diagrams posted by Warren Hall.
Emissions testing:
Tank ventilation-MFI diagrams
Last edited by David E. Clark; 05-14-2009 at 04:30 AM.. Reason: Update to add new links and specific post numbers.
Old 05-06-2009, 09:35 AM
Autodidactic user
Filter:
Replacing the MFI Fuel Filter from Porsche 911T/E/S Model '73 Driver's Manual page 62. Posted in Ultimate MFI Resources Thread. Post # 5.
1973 MFI Electric Fuel Pump questions. Importance of cleaning the filter screen located as part of the outlet fitting from the fuel tank (Post # 12).
Fuel Lines:
Braided Fuel Hose for a 72T MFI. The correct fuel lines and replacement methods for MFI systems.
Fuel pump:
BOSCH 2.4 MFI Fuel Pump. Fuel pump specs.
Help with MFI symptom. Measuring proper fuel pressure and why it's important.
Clogged Fuel Pump/Pickup:
MFI / CMA revisited ... The fuel tank should be drained and removed [remove the fine bronze filter screen at the outlet fitting] ... and cleaned & sealed with a slosh/seal product such as what is commonly used for light aircraft fuel tanks. Blow out the fuel line in the tunnel with compressed air ... to see if any rust particles are still clogging the fuel flow! Replacement of the line may be necessary to achieve the specified fuel output of 900 cc - 1000 cc in 30 seconds!
General Information:
MFI simplification thread
. Overview of each of the parts of the MFI system.
Autosolve Mechanical Fuel Injection article. Really deals with the Bosch K-Jetronic system but still a pretty good read.
Excellence Magazine technical notes II, pages 60-66.
John Cramer's MFI/CMA mnemonic aid. Posted in Ultimate MFI Resources Thread. Post # 24.
Mechanical Fuel Injection 101 by Grady Clay. Wonderful foundation for new MFI owners and as a reminder for those more experienced with MFI. Posted in Ultimate MFI Resources Thread. Post # 26.
MFI Message Board Index.
Project 30, page 91, Mechanical Fuel Injection Troubleshooting and Adjustment, 101 Projects for your Porsche 911
The Bosch Mechanical Fuel Injection Compilation by John Hunt.
Up-Fixin der Porsche has various somewhat helpful bits on Mechanical Fuel Injection at:
"Mechanical Fuel Injection" in Volume 5, page 146. Compares MFI to CIS and carburetors.
"Mechanical Injection" in Volume 6, page 31. Short discussion of gas in oil problem with some MFI systems.
Hot start issues:
Understanding and dialing-in the system for the first time. Detailed thread about setting up and troubleshooting an MFI system. Also discusses Hot Start issues.
Idle:
Adjusting MFI Engine Idle, Factory Workshop Manual, 1972 Supplement, volume 2, pages 3.1 1/2 - 3.1 1/3. Posted in Ultimate MFI Resources Thread.
Induction Chart:
MFI Induction Chart. Dimensions of the various MFI setups.
Injection Pump:
MFI Pump Dyno build- My newest project. Terrific thread with great pictures showing a homemade MFI pump dyno.
MFI Pump - Open Heart Surgery. Thread with great pictures showing the internal components of the MFI pump.
Adjustment of the internal partial load adjustment screws
Very technical MFI question..... Discussing the internal makeup of the MFI pump.
MFI Pump - removal, rebuild & re-fit. Nice guide to replacing an injection pump including timing the pump with great pictures. From a UK web site
Maintenance:
Fuel Injector Maintenance. How to maintain mechanical fuel injector.
Message Boards:
EARLY 911S REGISTRY has a good message board (not as good as Pelican). (I can't link directly to the web forums from here for some reason) Become a member to search for advice from other MFI owners.
PELICAN PARTS 911 TECHNICAL FORUM. The best 911 message board on the net!
PORSCHE CLUB OF AMERICA MFI TECH QUESTIONS. Put MFI related search terms (keywords) into the search box for advise from other MFI owners.
RENLIST TECH FORUM. Choose "web forums" from the first page and then 911 forums. (I can't link directly to the web forums from here for some reason) Become a member to search for advice from other MFI owners.
DDK - Die Deutschen Klassiker, 911 Technical Archive. "The 'Maverick' Porsche Club for Classic Porsche 356, Porsche 911, Porsche 912, Porsche 914 & Replica Fans"
Australian Typ 901 Register. General & technical discussion topics about early 911s.
6speedonline.com Forums. 911 1964- to current Porsche 911, from the air-cooled days to the current 997.
Micro switch:
Adjusting MFI Micro Switch - Beginning with 1972 Models, Factory Workshop Manual, 1972 Supplement, volume 2, page 3.1 1/4. Posted in Ultimate MFI Resources Thread. Post # 17.
Old 05-06-2009, 09:36 AM
Autodidactic user
Mixture Adjustment:
MFI Mixture Control. Good advice about setting pump mixture like: "Remember the phrase "I Lean Left" for "idle screw lean to the left-- and then remember that the main rack is the opposite of the idle rack, so the main rack is lean right, rich left" and "Everyone you talk to will stress the LAST thing you do is adjust the mixture ... All this does is to get you farther from a solution and many times causes more problems.
Mnemonic aid:
John Cramer's MFI/CMA mnemonic aid. Posted in Ultimate MFI Resources Thread, post # 24. Keeps you from getting your nice CMA manual all greasy!
Motor Break-in:
Octane requirements:
MFI and Octane. Discusses the advantages and disadvantages of different octane fuels in MFI cars.
Overview:
Mechanical Fuel Injection 101 by Grady Clay. Wonderful foundation for new MFI owners and as a reminder for those more experienced with MFI. Posted in Ultimate MFI Resources Thread, post # 26.
Mechanical Fuel Injection by Leslie Rice. Wonderful overview of the MFI system from a guy that really understands it. Great advice like "NEVER DEVIATE" from the sequence outlined in Check, Measure and Adjust.
Porsche Panorama Magazine has a decent overview article called "Porsche Mechanical Fuel Injection Systems" in the April 1999 issue at page 30.
"Mechanical Injection Pump Rebuilds" in Volume 7, page 120. Idle adjustment on MFI cars.
"Mechanical Injection Pump Rebuilds" in Volume 7, page 121. Rebuilders addresses current as on July 1986. More recent information about MFI rebuilders can be found here.
"Mechanical Injection" in Volume 8, page 125.
"Mechanical Injection 911T" in Volume 8, page 125.
Protractors:
MFI Protractors and Indicator. Last post by Grady Clay explains the use of MFI protractors.
More fun with MFI. On page 2 of this thread, Grady Clay explains the use of protractors.
Rebuilders:
"Mechanical Injection Pump Rebuilds" in Up-Fixin der Porsche, Volume 7, page 121. Rebuilders addresses current as on July 1986. More recent information about MFI rebuilders can be found here.
Supertec performance. See an example of their work at post four in this thread.
Eurometrix. Click here for pictures of their work.
Pacific Fuel Injection. Click here for an interview with the owner or here for some pictures of their equipment.
Regulator:
Repair Instructions:
Bosch MFI Repair Instructions. Just follow the link from the homepage to this article. Detailed repair instructions including useful torque specs.
Page 4: Introduction
Page 4: Disassembly
Page 4: Clamping the Pump
Page 5: Dissembling the Mixture Control Governor
Page 8: Dissembling the Compensating Unit
Page 10: Disassembling the Injection Pump
Page 14: Inspection and Repair
Page 15: Assembly
Page 15: Assembling the Injection Pump
Page 23: Assembling the Compensating Unit
Page 26: Assembling the Governor
Page 29: Fixtures and Tools
Page 30: Auxiliary Tools to be Made on Site
Page 31: Tightening Torques
Bosch MFI Repair Instructions, supplement 2. Just follow the link from the homepage to this article.
Resource Information:
MFI Message Board Index and Mechanical fuel injection resource index.
Last edited by David E. Clark; 05-14-2009 at 04:31 AM.. Reason: Update to add new links and specific post numbers.
Old 05-06-2009, 09:37 AM
Autodidactic user
Search engines:
The search function on Pelican Parts is your best friend.
Solenoid:
MFI speed switch and fuel shut-off solenoid. Describes how the MFI speed switch and fuel shut-off solenoid work and has electrical diagrams posted by Warren Hall.
RPM Transducer/Speed Switch for Bosch MFI diagram. Posted in Ultimate MFI Resources Thread. Post # 3.
Spark plugs:
Warning ... Error at NGK website. Discusses an error at the NGK website for the 72-73 911E and makes recommendations for proper MFI sparkplugs.
Speed switch:
Diagnosing the MFI RPM Transducer/Switch Help and 2.4 MFI idle intermitant prob. Diagnosing faults such as popping from the velocity stacks, poor idle and backfire caused by the MFI speed switch.
Starting issues:
MFI, 1972 warm-up issues (combined). L O N G thread which also contains lots of information about the MFI thermostat, miscellaneous cold start issues and having patience with the MFI system.
Storage Instructions:
Storage of Fuel Injection Pumps – Porsche 911 T, E, S, pages 47-52 Porsche Mechanical Fuel Injection, Check, Measure, Adjust (#4532.21). Posted in Ultimate MFI Resources Thread.
Confession: MFI pump not correctly stored. Tips on proper MFI storage. Kurt V posts # 4 & 12.
Technical specifications:
Porsche Technical Specifications - 72, 73 Models Fuel Injection System pages 54-55. Posted in Ultimate MFI Resources Thread. Post # 4.
Thermostat:
MFI thermostat spacers. Terrific thread about MFI thermostat spacers, what they do and why a properly functioning thermostat is essential for a properly functioning MFI system.
Timing:
MFI pump timing theory and MFI Pump re-installing and crankshaft timing mark help. Showing the proper timing method for the MFI pump along with a diagram but ultimately concluding that exact timing is not very important.
Injection Pump Belt Replacement. Post # 6 explains the procedure.
Last edited by David E. Clark; 05-14-2009 at 04:33 AM.. Reason: Update to add new links and specific post numbers.
Autodidactic user
Throttle:
diagram.
Throttle body linkages diagram from "Porsche Service Repair Handbook" Clymer Publications (1976) page 210. This same diagram is on page SF22 of the Factory Workshop Manual (April 1972 edition).
MFI Throttle body repair instructions. German repair instructions with great pictures.
Tools:
MFI Tools. Shows what tools are necessary for working on the MFI system and even discusses building the tools yourself. DOES NOT discuss the use of protractors.
Troubleshooting:
Fuel Injection Troubleshooting Chart, Factory Workshop Manual, Volume I, pages SF28-SF30. Posted in Ultimate MFI Resources Thread. Post # 21.
Project 30, page 91, Mechanical Fuel Injection Troubleshooting and Adjustment, 101 Projects for your Porsche 911.
Resolving MFI problems and more MFI problems. Detailed threads about working through MFI problems using CMA as a guide.
Troubleshooting MFI problems. Another thread with loads of useful information about tracking down MFI problems.
Any good MFI people out there? Understanding and dialing-in the system for the first time. Detailed thread about setting up and troubleshooting an MFI system. Also discusses Hot Start issues.
Need MFI help or advice...PLEASE. Long thread with lots of general advice for troubleshooting the MFI system.
MFI Tuning help. Advice for tuning MFI systems.
Question for the MFI people out there.... Nice detailed troubleshooting overview.
Warm up:
Web sites:
Workshop Manual:
Factory Workshop Manual, Volume I, pages SF 11 through SF 42. These pages give a description of the system along with useful schematic diagrams. Of particular help is the three page "Fuel Injection Trouble Shooting Chart." pages SF28-SF30. Posted in Ultimate MFI Resources Thread. Post # 24.
SF11: General
SF14: Description of Injection Pump
SF15: Operation of Injection Pump
SF16: Control and Compensating Units
SF16a. Control Unit
SF17b. Compensating Unit
SF19: Basic Adjustments of Engine
SF20: Basic Adjustment of Injection System
SF21: Special Tools
SF28: Fuel Injection Trouble Shooting Chart
SF31: Removing and Installing Injection Pump
SF34: Replacing Spur Wheel Belt
SF34a: Replacing Spur Wheel Hub
SF34b: Torque Settings
SF35: Adjusting Fuel Injection Pump with Emission Tester
SF40: Air Flow Rates
Factory Workshop Manual, 1972 Supplement, volume 2, pages 1-1/1 through 1-2/3; 3.1 1/1 through 1/4. Contains useful information about adjusting the injection pump with an emission tester and adjusting the micro switch on the 1972 and 1973 models.
Adjusting Fuel Injection Pump with Emission Tester, Factory Workshop Manual, 1972 Supplement, volume 2, page 3.1 1/1. Posted in Ultimate MFI Resources Thread.
Adjusting MFI Engine Idle, Factory Workshop Manual, 1972 Supplement, volume 2, pages 3.1 1/2 - 3.1 1/3. Posted in Ultimate MFI Resources Thread. Post # 7.
Other Workshop Manuals:
Ball, Kenneth (Autobook) Porsche 911 Owners Workshop Manual, pages 41-42 (1974).
Chilton’s, Porsche 2 Repair & Tune-Up Guide 1969-1973 (1974). No MFI information.
Clymer, Porsche Service Repair Handbook 1965-1976 (1976). Information only on mechanical fuel pump, pages 211-213.
Dempsey, 101 Projects for your Porsche 911, Mechanical fuel injection troubleshooting and adjustment, pages 91-94 (2001).
Drake, Porsche 911 Range: 1968-1972, pages 71-75 (1972).
Glenn's Diesel and Gasoline Fuel-Injection Manual, mechanical fuel injection, pages 1-30 (1973). The best MFI explanation outside of the Factory Workshop Manual and this board.
Haynes, Porsche 911 Automotive Repair Manual, Pages 62-67 (1990).
Hollander, Foreign Interchange Manual (1975). Lists no interchangeable parts.
Intereurope, Porsche 911/912 Workshop Manual Pages 76-78 (1972).
Morbye, Automotive Fuel Injection Systems - A Technical Guide, Bosch Mechanical Injection Systems, pages 53-60 (1981).
Last edited by David E. Clark; 05-14-2009 at 05:06 AM.. Reason: Update to add new links and specific post numbers.
Old 05-06-2009, 02:35 PM
al lkosmal's Avatar
David,
Wow...thanks for doing this. You are my new best friend.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-09-2009, 08:36 AM
Michael - 69E's Avatar
Great stuff!
Bet I will need to do some reading when I get my throttle bodies back from refurb
Michael
Blut Orange 911 E, 1969
Indisch Rot 911 Carrera 3,0, 1977
Alfa Rosso Alfa Romeo GT Veloce, 1967 (SOLD )
Old 05-10-2009, 12:45 AM
Autodidactic user
Old 05-14-2009, 03:22 AM
David, is there any interest in reproducing the P228b and P228c protractors? Believe it or not, I just bought a complete set of NOS protractors (they even came in the original Porsche parts boxes) from a retiring Porsche mechanic. After looking over the protractors, it seems that it would be possible to make a set without too much difficulty. Just curious as to whether there would be any interest in reproducing these tools.
Toby
Toby Pennycuff
Dallas, TX
1979 930 Petrol Blue Monster
1968/1973 911S MFI #73 - Tweety Bird. 911 PCA Club Racer. E Prepared
2001 GT3 Cup #77 - O M G!
Old 05-14-2009, 05:54 AM
Autodidactic user
Toby
One of the long time members Milt AKA Zeke undertook this project several years ago but abandoned the effort after concluding the it was not feasable. Here is his latest thread on why he abandoned the effort (post # 5). I'm sure there would be interest if you could figure a way to make these accuartely and at a reasonable cost. Since Porsche concluded that the protractors were not necessary way back in 1972 (post # 32), I don't think anyone would be willing to pay more than a couple of hundred dollars max for copies. Just my 2¢.
P.S. Are you the guy that bought the NOS set that sold on eBay in the last few weeks?
Old 05-14-2009, 06:31 AM
Yes I am and I did. I also found a separate set of the earlier 2.2 protractors from a retiring Porsche mechanic. They too, did not sell for anywhere NEAR the prices asked.
Toby
Toby Pennycuff
Dallas, TX
Old 05-15-2009, 06:17 PM
dtw dtw is offline
GAFB
Heads-up - I've tried to download the CMA guide a few times this week, and the link appears to be dead.
Several BMWs
Old 06-09-2009, 01:17 PM
Autodidactic user
Thanks. For some reason I've lost my ability to edit that post. I'll send an email to a moderator to see if he/she can fix this. For now, here is a link from the early 911S registry to the CMA manual.
Old 06-09-2009, 01:33 PM
pszemia's Avatar
The CMA link is not working propetrly...
911 T 2.4 (MFI) 1973 with 911 E fuel pump from 1971
The beatiful Buenos Aires, Argentina!
Old 03-20-2010, 06:51 AM
Autodidactic user
I still can't edit this thread. The link posted in #15, right above yours, is working!
Old 03-20-2010, 07:00 AM
Banned
Send a message via ICQ to priligybay
nothing else
nothing else needs
Old 04-20-2012, 02:39 PM
surprized thanks
I'm new here , nice thread!
Old 05-28-2012, 03:52 PM
Hi, I havent found a working CMA download link. Could someone please point me to a working link? It would be appreciated....
Regards,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 06-30-2012, 02:27 AM
