Any pictures of Tool Sets
Anyone know if there are color pictures available anywhere of what tools should be in our Porsche's tool kits.
I would like to find out what tools should be in the set for my 83SC, the ones in there right now are Grey, Gold and black (not dirty )and if I have the right one I could clean them up and send the off to the platers.
Old 11-28-2007, 03:52 PM
Make Bruins Great Again
Por_sha911's Avatar
I seem to remember a picture being posted in the past. Try searching this forum for Factory tool kit and see if you can find it.
Joe
Old 11-28-2007, 03:58 PM
Not sure but i HIGHLY recommend picking up a 13mm ratcheting wrench for the hard to get to bolt in the back right of the AC compressor. A regular ratchet wont work, too big to fit. This will come in handy if you need to change your fan belt if it breaks at the most inconvinient time. You will be able to move the ac compressor without hassel. In the winter this doesnt matter as much, because you can just cut the ac belt and toss it on the side of the road, replace it later. But in the summer, its nice to keep the ac going after a belt change.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 11-28-2007, 04:01 PM
Driver
Noah930's Avatar
I posted this pic a few months ago, due to a similar request. I don't know if my kit is complete, or the same as what would be found in an '83. My car is an '87. But all tools are stamped with "Germany" or "Klein," with the exception of either the crescent wrench or pliers (can't remember which one, but it's stamped with "Japan") which was added by one of the POs along the way.
1990 Black 964 C2 Targa
Old 11-28-2007, 04:13 PM
kilodawg's Avatar
Why not just go to the PET for your year. It specifies contents in detail...
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 11-28-2007, 05:05 PM
304065's Avatar
Ditto PET. Never was a crescent wrench although it's a good idea. Never was a corkscrew either. . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-28-2007, 05:11 PM
KatoKato's Avatar
When my battery boiled over this summer I had to remove all of the tools, clean, etc...
Does anyone have a pic of how they're supposed to go back inside?
Old 11-28-2007, 05:15 PM
This should do it... no crescent, and the screwdriver handle on at least early SC's are yellow. Red on earlier (longhood, I'm pretty sure) cars.
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_78_83_KATALOG/001-00-Frame3.htm
Sorry I couldn't get the diagram to show on the email, click it, it's a great source.
Old 11-28-2007, 07:11 PM
what is this tool?
Old 11-28-2007, 07:15 PM
HarryD's Avatar
Originally Posted by rusnak View Post
what is this tool?
My '73 does not have that tool but it may be an allen wrench with a rubber cup at the end to remove and hold the lower bolt from the battery holddown.
If you have the owners manual for your car (as I am sure we all do ), there is a picture of the tools included in the car.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-28-2007, 11:29 PM
Southern Class & Sass
Dixie's Avatar
what is this tool?
The tool is for manually cranking the sun roof.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 11-29-2007, 03:30 AM
group911@aol.co's Avatar
That tool wasn't in the kits until the 3.2 cars and they started using allen bolts to clamp down the battery.
I don't recall the sunroof using an allen
Here is a picture of a completely original kit from an 81 SC including the tools in their original place. . head.
Thanks,
Bob
group911@aol.com
Old 11-29-2007, 04:12 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest
No, that's not the tool for manually cranking the sunroof. It's for removing and holding the bolt for the battery clamp.
Here you can see my '85 toolkit which is definitely complete.
The tool third from the left at the top is the one for manually cranking the sunroof.
And the original tire inflator.
There's also the jack and a plastic bag (to put your punched tire in) and some latex gloves.
Kees.
Old 11-29-2007, 04:15 AM
MBEngineering's Avatar
HI rusnak
the allan key is for removing the battery on a 911 SC, as it has a large battery and a allan key holding the battery clamp, (also in the 928), there should also be a short peice of tube to slide over the alan key to loosen the battery clamp, that kit is also missing a 10mm alan key for the plug socket, fan belt, small packet of fuses, speed wrench for the electric seat, for manual seat adjustment if the motor fails, towing eye,sun roof handle (if applicable), (the adjustables would not be in there)
the handle is to be removed off the driver and fitted to the end of the speed wrench for the seat adjustment.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 11-29-2007, 04:23 AM
That's the sunroof crank on the clear plastic on the right, by the latex gloves.
Old 11-29-2007, 07:14 AM
Kees,
Looking at the right side of your photo, what is the tool with a spring on it?
Thanks,
Tom
Old 11-29-2007, 08:34 AM
Originally Posted by trconway View Post
Kees,
Thanks,
Tom
Spark plug wrench (socket).
Old 11-29-2007, 08:47 AM
Thanks guys for the interesting info.
I didn't know I was missing an allen wrench, and I am way surprised that some 911s came with speed wrenches?!?
Ok another question: what's this doohicky?
Old 11-29-2007, 09:47 AM
Rod goes into the spark plug wrench at right angle to turn it, I think. Have an Owner's manual?
Old 11-29-2007, 10:15 AM
My '84 owners manual only describes where the tool kit is located, and that some countries required additional tools, that's it.
My spark plug wrench has a hex fitting for an allen wrench. That rod looks like it's cylindrical or tubular.
Old 11-29-2007, 10:20 AM
