That looks right to me. The White/Green wire is the suply (+12V) side of the blower. I do not see how the blower could work if the fuse holder was spliced in series into that wire and you don't have a fuse installed? Also, that holder looks like someone added it, that's a modern style fuse, not sure if Porsche used those style fuses?
Maybe the fuse holder is internally shorted or the wire job is really poor. Also, I have a 84 Carrera and do NOT have those fuses on my footwell blowers.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
The top pic is the footwell blower. The connector will have the green/white & brown wires inside the black plastic sleeve. If that fuse holder is spliced into that green/white wire the blower should not run without a fuse in place. If it does I would check the splice to see if there is bare wire touching somewhere.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
You also can simply test for 12volts at the harness when the rotary switch between the seats is set to hi (pos #3) and you must also pull up the orange heat levers to activate the heat system.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 08-13-2008 at 11:20 AM.. |
Sal, it looks like we are on the same page but you're faster on the draw!
Drivers side pic: ![]() There is a brown wire there that is cut. Is this normal? Now the question is - should I put a fuse into the passenger side blower and see what happens??? Or just leave it as is??? (I'm happy with how the heater works as is) Perhaps someone has modded the system in the past to work this way and I shouldn't mess with it.... Cheers, Kato Last edited by KatoKato; 08-13-2008 at 06:07 PM.. |
The fact that the driver blower works is a very GOOD sign and indicates the rest of the heat system is working. You are way ahead of the game knowing this.
Hey all...ok, my take on this is that the PO used the blue wires to connect both footwell blower together. Then the single fuse blew..so he bypassed the fuse with a metal slug down inside the fuse holder or spliced wires to bypass the empty fuse holder. Its kinda hard to tell from the pictures but the blue wires don't look OEM nor do the cut brown wires.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
That reminds me.... I gotta add this to my project list.
86 Carrerra (no footwell blower fuses)
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
I think I remove and test the unit. Just to be sure.
That blue wire leads to my fuel pump kill switch....but I do suspect that the PO has done something unusual to these blowers. Thanks all and I'll report what I find. |
Update:
Pulled the unit out and tested it. I think the PO removed the fuse because it was noisy. The fan blade was rubbing against the bottom of the casing. So I took it apart, cleaned/lubed the motor, and sanded away 0.5mm or so for fan clearance. Put it together and now it runs like it's new! Sweet! Thanks for everyone's help. Cheers, Kato |
So how to fix it? Pry the fan off the shaft - (it can be done) then re-set it with epoxy onto the shaft leaving a few mm of gap from the housing. Your quick fix will work but not for long trust me. Here's an old thread with the details of this problem: http://forums.pelicanparts.com/showthread.php?t=113997
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 08-14-2008 at 11:20 AM.. |
Cheers, Kato |
And while at it put a little silcone grease on the bushings.
Is there another way to try and set the fan other than using epoxy?
Others have simply cleaned the shaft and fan and put it back together with a spacer of some sort to keep the fan from touching the housing. Maybe a few plastic washers?
Yes that would do it. What about keeping the fan from contacting below? From what I've read in the thread you posted above these things can fuse either above or below....
I've only seen the fan fuse to the motor side housing. Not sure much could be done in the other direction? Guess you could put a dab of epoxy (after you re-assemble) at the end of the shaft to be sure the fan does not slide off - just a thought.
[QUOTE=Barrpete;4056894]I looked when I did the install & couldn't find any. It really is pretty easy though. Just remove the kick panels & unplug the harness from the fan. The wires are wrapped in a plastic sleeve that you'll need to cut back far enough to have room for the splice. There should be a brown wire which is the ground & a green with white stripe that is the hot. /QUOTE]
Sorry to resurrect an old thread. I’ve done a search for a couple of days and this is the only thread that details the inline 10A fuse for the footwell blowers that I’ve found. I have an ‘86 as well and the footwell blowers are the only things left that I need to attend to. I have size 14 gauge fuse holders (w/ the red wires) but before I cut into the OEM wht/grn wiring, I was wondering if there is a cleaner way to do this. I have the heat shrink solder as well as the crimp type connectors. Edit: I used the 3M fuse holders. No additional connectors or soldering. Just cut the grn/wht wire once and snap both ends closed over the butt ends. http:www.crowbarelectricalparts.com/3m-scotchlok-fuse-holder/ Last edited by Cujo911; 01-30-2023 at 01:52 PM.. |
