On the rear fender condensors, will you still be able to get at the rubber bellows on the bumpers easy? Or will it be harder to take off the bumper now?
1986 930 |
I believe the two types of nylog depends on what pressure you are running not the type of refrigerant. I went with the blue based on operating pressure.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Throw it on the ground!
Some more pics from todays adventures.
Griffiths Kuehl kit comes with a evap baffle to direct all air flow through the coil. ![]() ![]() To wrap the box I used one layer of 1/8" closed cell dynamat foam followed by a layer of 1/8" foam with foil from home depot and a roll of aluminium foil duct tape. This added a full 1/4" and made for a snug fit going back in the smugglers box.....any larger and it would not have gone back in. ![]() ![]() ![]() Here is the condenser unit mounted in front of the rear tire. I had to move the upper mounting bar that bolts to the Seat belt retractor mounting point to raise the entire unit up so it did not rest on the torsion bar cover. Oh, and here's the best part. After removing the seat belt retracter, we could not get it to extend...tried to unlock the mechanism with no luck....in a last ditch effort we ( we = Paul "carnutzzz") popped the cover off and the spring came flying out....fortunately no one got hurt!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 03-09-2008 at 04:18 PM.. |
Great stuff Mark, subcribing for next year!!
O2 In Sully We Believe |
1985 911 Coupe Black 1985 911 Cab GP White (killed) |
No, just a shadow line.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
You will be freezing this summer, and enjoying every moment. It is great to have good A/C in a 911. Enjoy!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Subscribed. I'm doing a Rennaire kit this spring.
Scott '86 911 Carrera Coupe, PCA, PBC |
911 addict
I bought all of the components of the Rennaire system individually, as I did not originally plan on doing the whole kit.
Does anyone know if there is a difference in the evaporator orifice for R134 Vs. R12? I don't remember being given a choice when ordering from our sponsor, but could have been an oversight on my part. I'd rather find out now before I install it and use it. I plan on using R12, so it could be a problem if it was designed for R134. Thanks
1987 Carrera Cab Toyota Landcruiser 500SL |
subscribed
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
I knew I was going to get blamed for the seat belt mechanism "incident".
Hey- when it comes to labor ya get what you pay for! |
Followed your advice and ordered this pump and a guage set from thetoolwarehouse.net. Order placed this AM, shipped this afternoon and will be delivered tomorrow & free shipping to boot! Thanks for the recommendation.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 03-10-2008 at 09:59 PM.. |
911 addict
Thanks Mark- if you are interested in renting it out for a day or two when you are finished it may help recoup the cost- I don't know what part of town you're in but I would be happy to help subsidize the cost. I have a set of Snap-on A/c manifold gauges if you need them.
My system is going to be the complete Rennaire kit with Desert Duty condenser, except that I ordered the "Jim Sims pro-cooler" to try instead of the pricier option from Rennaire. I'm hoping to get a good leak free system (and using the Nylog goo) and will try and stick with R12. I removed the front factory condenser this weekend- do you think all of the DD condensers are shipped with bolts too short, or will I need longer ones also? Thanks Rick
1987 Carrera Cab Toyota Landcruiser 500SL Last edited by mtbguy; 03-11-2008 at 06:29 AM.. |
what the best book on car AC that best applies to going from R12 to R134 - there are bits and pieces explained in many posts. When I dive into this I want to have a good list and process for evacuating and charging properly. I like the idea of getting a vacuum pump and DIY. I have an 89 coupe and planning to completely redo the ac system this summer. So I need to decide on model of new compressor, hose kit or DIY hoses, 3 way valve, ProCooler or no ProCooler/etc. Right now I'm leaning toward keeping the same evaporator and condensor assuming there are no leaks.
Original Owner
If you're doing this as a first A/C project I recommend this book.
http://www.acsource.com/index.asp?PageAction=VIEWPROD&ProdID=8 From Mastercool. Covers all you need to know about R-12 v R134a. High low pressure targets. (They are different). Components, troubleshooting, how, when, where. to add oil. and so on...high/low switches. Fan controls...
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Rick, happy to work out a deal with you on borrowing the vacuum pump. I'm in Roswell. The issue with the bolts is this. There are two bolts on the passenger side and one bolt on the driver side. Due to the thickness of the DD, the cage drops down leaving a gap between its mounting tabs and the tub. The kit supplies washer spacers but they are not thick enough. I used addl washers to close the gap. I was only able to use one of the supplied bolts on the pass side as the other was obstructed by the crash bar....so I only used one bolt on that side. The drivers side is where the supplied longer bolt is too short....you will need to pick one up at the hardware store that is 1/2" longer. IIRC is is an M6 bolt and you will need one that is about 1- 1/2" long.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 04-13-2008 at 06:28 PM.. |
