Anyone rent the jig for drilling out broken exhaust studs (3.2)
Hey all. While having the valves adjusted on my 3.2 Carrera (at a reputable Porsche shop), I was told I have a broken exhaust stud in #3 cylinder. They quoted $500 for the job. Bummer!
I am a DIY type on basic tasks, so I was wondering if anyone rents the jig needed to drilling it out? I also wonder, when the exhaust systems comes off will the act of removal break others? Thanks
- Bob Last edited by Bob Prosser; 04-17-2008 at 06:36 AM.. |
Will program for food
AQUIETBOOM (on this board) sells a tool for just this purpose. PM him for details. I have one on the way as a matter of fact...
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Thank you. Wow, talk about niche market cottage industry. Thinking ... by the time I buy that part (or rent one from a fellow PP-er), and the right bits, bolts, etc., I wonder ... does the $500 shop estimate sound about right?
And since the manifold has to come off (I assume), I'm wondering how many other bolts will break, which I am sure runs the estimate upward.
- Bob |
you will break no bolts, IF, you heat the nut red, one at a time with a oxy/acetylene torch and remove it while it's still a dull red. bright red allen nuts tend to round out and create a removal problem, so wait a few seconds until it dulls out a bit.
Just curious, would a small MAPP gas torch be adequate for this or is an oxy/acetylene setup required to get it hot enough?
Dan in Pasadena '76 911S Sahara Beige/Cork |
No way you will get it with MAPP. I tried, but I have an East Coast Car. For the record, Christian's tool works great, is not ridiculously expensive, but the job is a PITA, especially if you're doing it on your back. But then again, I drilled them all out.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
I'm going to drop the engine on my '82 SC soon to chase down some leaks and do some other cleaning and adjusting tasks and I was wondering if, given the fact that I may go to an early SSI exhaust in the near future, whether I should remove the current exhaust system and replace the studs, since the engine will be on a stand?
1982 911SC 1987 924S |
I would do it while then motor is out. Certainly a lot easier to put heat on it.
AQuietBoom stud removal gizmo seems to be the cat's ass.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
sudo apt-get purge 930
That's being conservative. I just used mine and drilled out 8 studs, chased and cleaned the threads, and installed 12 new studs in 4 hours with the engine in a stand. Christian's tool is effing awesome. I told my wife there are some tools that are worth every penny you spent on it and that is definitely one of them.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Thanks for the kind words about the tool guys. I must give credit where credit is due, the original design is John Walkers, I'm just semi-mass producing them. Bob, I don't list the price of the tool on the board out of respect for Pelican Parts, PM for details.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Gents, get this: I just lifted the side of my 911 to see this broken exhaust stud for myself. What do I find? Nothing but a hole. A 33 mm deep hole to be exact.
If you look closely here, you can see threads deep inside. ![]() Doing some research, I see a replacement exhaust stud is an M8 x 50 mm. (Pelican Part #999-062-239-02-M260) In other words, it looks like the bolt fell OUT, and didn't break OFF as I was told by the shop. A $5 bolt plus 5-minutes to install, instead of a $500 estimate! Jeez, I hope the mechanic's eyes were bad, and they didn't think I was a rube (memo: don't wear an expensive watch when you take your car to a shop). Thanks anyway for everyone's input.
- Bob Last edited by Bob Prosser; 04-17-2008 at 03:07 PM.. |
I used loc-tite on studs
Sounds like you dodged the bullet on that one! Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I would still get the tool from Christian if you plan on keeping the car or doing this type of work in the future.
I used timeserts, but the next time I'll be using Christian's tool, since one now resides in my tool box. I used anti-seize on my bolts.
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Seems like no one ever mentions it but go grab a bottle of Anti-seize (Silver container - get a good sized one for $5.00) and paint those studs! If you want to know for sure you can get a bolt or nut off when you come back to it; Anti Seize is the way to go.
I painted the whole Stud/Nut assembly after I had it them tightened down for good measure - the stuff will smoke as the exhaust heats up but one of its' recommended uses is Exhaust Hardware - good to 1700F or some absurd number.
1989 Carrera 3.2L in 993 bodywork |
