AC Compressor leaking oil?
All,
Need your help on this one. I have a 993 C2. I am finding streaks and build up of oil inside the rear deck lid and on the right side of the the engine compartment. Tracing it, it looks like the oil is coming from AC compressor clutch. The oil looks like it is leaking and being flung from the front face of the compressor clutch. Is it safe to assume that the compressor internal shaft seal is toast and will need to be replaced? So, far my AC is still working fine. thanks, anthony |
Haha, that is funny, I was just about to post the same issue today.
I too wonder if the compressor leaks oil, here is the pic of the streak under my engine lid, 87 Carrera, perfect working AC as well... I use Brad Penn oil and the oil on the lid isn't green or is it?? I'm color blind.
Another pic near the motor mount-
Mine looked EXACTLY the same!!!!
Mine too!!
Ken 06 Cayman S - gone 85 911 Targa - gone back home to Germany 73.5 911T Targa - long gone... Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs |
Anyone home from work that would like to chime in on this issue
![]() I felt around the compressor pully and nothing was oily, seemed only to have a very slight film but was not dry. The leak must get worse when the clutch pully is in rotation. Is the AC compressor shaft seal a DIY job or does that mean it's on its last legs and new compressor time
You better get the freon out soon before you lose it all, damn expensive stuff these days. Now about the shaft seal, yes it can be replaced, but I seldom do them. I did one a Buick a few weeks ago and the damn compressor failed right after. Seems it all wears together sometimes. Get a rebuilt compressor, evac the system and save that precious R12, replace all the o-rings since you have it empty, new accumulator, check and clean the expansion valve. Vac for leaks, pull vac for 45 mins or so and recharge.
Get ready to open the pocket book when these r12 systems start leaking things, repair and or conversion gets expensive fast. Its been a busy AC season for me, however profitable
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Brorag
You will need a new or rebuilt compressor. Been there, done that.
jd |
No sleep 'til... BROOKLYN
I'm also eager to hear what others have to say about this because I'm about to buy an 88' Carrera and it appears that when they took the pic's the car had this problem, we can see the same oil streak on the engine lid.
![]() I asked the seller about it and he hasn't answered that one, I asked twice already so I'm starting to get suspicious. I already paid for the PPI. ![]() flatsix
-Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 |
Scott R,
You replace these for a living? I know one of the Porsche shops did AS as well, I would welcome any leads. Speaking for my year, 87, is the Denso unit OEM? $346 bones Vs. $1600+ for new OEM. Anyone rebuild these locally maybe near Boulder perhaps ![]() Thanks, if I don't use the AC can I still drive the car without harm to the compressor? Thanks! |
Make Bruins Great Again
The Nippondenso and Denso compressors are known for this problem. Yes it is a leak. You are slowly losing refrigerant. One day you will find the AC is warm. If you still use R12 fix it ASAP. As far as rebuilding the compressor and replacing the seal, I have been told that the new seal won't last too long so I switched to a Sanden. Someone with a different experience can chime in.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
And no, you won't damage the system driving it around with the compressor off. However, when something leaks out often times contaminants get in and cause damage to other pieces
I have the exact same issue with my 86. I recently had the R-12 refilled from our local mechanic and I asked him about the oil on the decklid. For what it is worth, he showed me a sort of wick at the top of the compressor that he says always will lose a little oil as long as the AC is on. Something about pulling oil to keep the compressor lubricated. Made sense but seems like a lousy design. Kind of tired of cleaning the oil off the deck lid every week or so. From these posts makes me wonder if that is indeed the case. Anyone else heard that theory?
Steve 58 356 Speedster 70 911S Targa, 73 914 2.0, 73 911RS Targa 05 Boxster,23 Macan T |
Pelican Parts Tech Articles has an excellent article on rebuilding the compressor.
Also, here is another rebuild article on Rennlist. http://forums.rennlist.com/rennforums/showthread.php?t=424999&highlight=compressor+clutch It seemed a very easy task, especially a 911 where the compressor is right in your face. |
Can I have the R12 put into a tank until I decide what to do, I'll fix it in a matter of months but to burn a hole in the ozone and in my wallet to let it leak out doesn't seem logical.
Do places like NAPA have the capability to drain it in a tank that I can purchase or will it need to be placed in a special tank for freon at a specialty Automotive AC shop? Any other places sell rebuilt compressors like Sanden since I can't see why I would rebuild it if it's a Nippondenso POS? Sorry, I am new to the whole AC thing but appreciate any help. Scott R, thanks for the shop recomendation! |
I've replaced that seal on my 88 twice. Once unsuccessfully and once successfully. Held fine for a couple of years till I went w/ the Sanden when I was in the mood to replace other stuff. Ken
Well, I opened the pulley cover and confirmed it's oil and dye leaking out of the shaft. See attached pics. Put a pressure gauge on it and see that I still have 34lbs of pressure of R134 (it's a 993).
I cleaned it up and out everything back together. Wonder how long can I go on like this. Maybe through this summer and rebuild it in the winter since it's my daily driver. ![]() -- anthony |
That is a 95 993. Hmmm.... are those R12 port? They are big. They fit my Harbor Freight AC gauge kit.
