Capitalist and Patriot
I know this already has been discussed many times here, however, I'm not having any luck with a search so....
Once warmed up my 3.0l oil pressure drops below 1 bar at idle (sitting in traffic) ![]() Sometimes as low as the half way point between 0 and 1 bar ![]() I thought there was a fitting you could put on a oil feed line that has a smaller diameter than the oem fitting, thus increases pressure, true? This has only been an issue now that I'm spending more time in traffic ![]() Engine has roughly 60k miles, strong compression and is maintained properly. Any insight would be greatly appreciated
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " Last edited by 911Freak; 12-13-2008 at 02:39 PM.. |
Idle oil pressure is irrelevent, there is no load on the engine and flow is all that matters. Porsche has stated this many times over the years, it is OK for the Oil pressure light to come on at idle. Does the light come on ?
Paul |
So I'm ok then? Thanks!!!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Air Medal or two
Oil restructures to the cam. A big over all improvement
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I assume only one is needed?
(On the right side of engine, correct?) And there it is, Pelicans coming through again! Thanks guys!
Yes,
Oil pressure paranoia is why BMW refused to fit OP gauges for many years. Several MFG's altered the range and markings because of the psychological effect of a below middle needle. Most people do not realize that modern gauges are non linear and designed to read in the middle unless extreme variations occur. More oil pressure at idle is not better, worry about something that matters.
Paul |
Air Medal or two
2, one on ea of cam tower.
Perfect, again many thanks for all the heads up & usefull info!
This is just another reason I need to get a better oil temp gauge as heat is the true killer of our beloved flat six engines! PSalt: excellent, makes perfect sense. Now I'm free to get back to working on suspension upgrades and paying proper attention to the traffic ahead of me not staring at the pressure gauge! I thank you as does everyone in front of me on the roads!!!
Band.
In addition, the cam oil line restrictors are a much-debated subject and if your pressure while driving is ok, then many folks here would suggest you NOT go for the cam oil lone restrictors.
I'll search for threads on the "cam oil line restrictors" and review the pro's and con's. My oil pressure while driving seems to just about match 1 bar per 1k rpm, unless the engine gets to full warm operating tepms FWIW: my engine never has gone above mid level on the temp guage Thanks!
Make sure you are using a good 15w-50 or 20w-50 oil.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Air Medal or two
OK, there was a big thread on this couple yrs ago,,consensus was, after break inn put them in. I did. No problems, no cam wear, all is well. And it is a Porsche part , they invented it
I would have to say.. I am not all that kind to my eng and it is in good shape since rebuild. I installed them probably 2 months after rebuild.
Band.
The restrictors reduce the amount of oil going to the cam towers, which is one of the areas that needs it the most. It increases the amount of oil that stays on the other side of the restrictors, which happens to be where your pressure sender is as well, thus raising the needle on your gauge a little bit and giving you a warm fuzzy feeling that you've done the right thing. That's my understanding See? Right on cue! And he's one of those guys who actually knows.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 12-13-2008 at 04:34 PM.. |
2 things...
First off, rule of thumb on any street engine is 10psi for every 1K of RPM. So at idle if the car is running at 750RPM, 1 bar (or 10psi) is more than adequate. Secondly, how can you be sure your VDO is accurate? Get a separate gauge, plug it in and see what it reads.
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. |
Max Sluiter
Your oil pressure is good. Do not starve your cams and valvetrain of lubrication by installing the restrictors. 10psi/1000rpm is good. Idle pressure can be less.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Listen to Steve.
My thoughts on this topic are in this thread - http://forums.pelicanparts.com/showthread.php?p=3174010&highlight=restrictor+oil#post3174010 and this thread: http://forums.pelicanparts.com/showthread.php?t=264526
Perhaps the REAL reason for Porsche to install the restrictors on the later models are simply to make the guage drop less at idle??
/Nimskov |
Air Medal or two
Dont know ....they must have had a reason..??
Yes they did.
Be aware that the addition of the restrictors came after the upgraded oil pump which puts out more volume at a given pressure. I suspect the flow to the heads remained about the same with the extra flow going to the piston squirters and bottom end. Besides, what would Steve and Grady know that many of us do not? Quote:
Habitual User
After reading Grady's quote I'm thinking the lesser of two evils is doing a top end not a bottom end. I think I'm all for working piston squirters. Right?
Don
![]() '80 911 Targa Last edited by BLEW911; 12-14-2008 at 12:15 PM.. |
