pryord's Avatar
Pressure Plate Question '67S
I see the pressure plate for my car is an S-specific aluminum model for around $700. Yikes. I'll bite the bullet if I have to, but are there other options I should consider?
1967 S
Old 01-26-2009, 05:36 PM
normal one works fine for must people, the original alumnium'S' one revs nicer and grips harder but they are kind of fragile and do not take abuse well at all. So the factory had a updated steel 'S' one that was swapped out in the day for the Aluminum one. I believe it is easer to find the steel 's' plate and it is a little cheaper than the aluminum one but of course way more than a normal. Unless you plan on running hard or you want to keep your 'S' all 'S' Normal is what alot of people do. I went with the steel 'S' plate.
Old 01-26-2009, 07:14 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I have a very nice used copper-face 67S Aluminum pressure plate for $220 shipped...
Email if interested, kindersport@gmail.com
Scott Kinder
kindersport @ gmail.com
Old 01-26-2009, 07:39 PM
