Package box repair?
hi,
i know probably all door package boxes in all 911-s are cracked where they are bolted to the door handles ... but it still bugs me. i asked the porsche center today how much they would charge, and the guy mentioned some 1900 (aussie) dollars ![]() not sure i'm at that stage of my relationship with the 911 yet ... has anyone tried to fix them? cheers georgie |
Go with RS door panels and eliminate the door pockets.
Designer King
Search "door pocket repair". Pelican "autovon" and others have made some successful repairs.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Yep. You will find several different repair techniques. Usually some sort of scab patch, plastic or aluminum. Some have drilled holes down the two side of the crack and kind of laced it back together.
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
I used Gorilla glue to repair the cracked cardboard (that's what they're made of) and applied a thin strip of fiberglass cloth and polyester resin on the inside over the crack. When I installed them I used slightly larger black-painted thin washers under the screwheads. They are notoriously weak. RS panels are not a bad idea if you don't mind the loss of storage and the stock look.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
What about the fiberglass ones that match the OEM cardboard ?
Only 125 (US) for the pair. Last edited by Wyvern; 04-17-2009 at 10:06 PM.. Reason: I cant SPELL ! LOL |
where? i thought our host marks them as no longer available?
thanks for your help. georgie |
come to think of it .. mine do look like plastic ... they are still cracked.
i think i'll try the aluminium reinforcement. georgie |
Mine were shot ...Yes ... anything can be rebuilt but, I picked up a pair of the fiberglass pockets. really quite inexpensive.
I re carpeted my interior and have the carpet for the pockets ... But, I wasn't a big fan of carpet on my doors and the pockets once cleaned up looked really nice. You do have to attach the partition / stiffener and drill mounting holes. I used some hammer finish texture paint first (hard to see in the photo) then painted with flat black.
some of the fibreglass versions are crap. I got some plastic ones that are perfect. Thats what the factory went to on the C2
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
