Engine Serial#
serial read's 6640113 can anybody tell me what its out of, it looks like its got possibly a #1 in front of it any help would be appriciated
thank you Ernie |
this may help http://www.elferhelfer.com/fzident/fzident74-77.htm
That engine is from either a coupe or Targa '74 Carrera 2,7. It is a type 911/83 MFI engine, the same type as used in the '73 Carrera. Do you have a photo of the serial # stamping?
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
I will take a picture and post it in the next couple of days I just looked at it again and it looks like it has the letters AT in front of the serial# but its late and my old eyes are tired but the stamping is definitely 6640113, thanks for the info
Ernie |
Still not able to take a good picture I leave in the dark and get home in the dark but I will get one tomorrow at some point, what is the value for this motor it has carbs on it now
Interesting. The stamping 'AT' would indicate you have a Factory replacement case for the original case from a '74 Carrera 2,7. Check out this thread from the Early 911 registry. Does the stamping on your engine look like the second photo in the tread?
http://www.early911sregistry.org/forum/showthread.php?t=5806&highlight=case Also, does the engine have the type # stamped on it? It should be type 911/83.
