Send a message via AIM to ronw
I never did weigh mine in isolation, but I've read 264 lbs dressed. I'm assuming w turbo, up pipe, down pipe, header,stock iac, AC , ps pump
Old 12-08-2013, 09:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #221 (permalink)
Wow. That would be amazing. Below is the list as I have it, with your numbers added:
2.0L 911 - 405 lbs
2.2L 911 - 380-405 lbs (magnesium case dropped weight)
POLO - 286 lbs
912 - 212 lbs - 240 lbs
Subaru - 264 lbs
914?
Raby?
Old 12-08-2013, 09:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #222 (permalink)
Here is a reference but in looking at the other weights, I'm not confident in the numbers comparing apples to apples ie, other motors weights seem higher and others lower.
http://fixrambler.com/engineweightchart.txt
Old 12-08-2013, 09:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #223 (permalink)
MichiganMat's Avatar
Send a message via AIM to MichiganMat
Originally Posted by car 311 View Post
mat, let me know when you guys will be working on it again, id like to come by and check the thing out. very cool 2nd phase to the project.
For sure. We need to hang out again, been too long. You gotta come over and checkout our setup, its pretty awesome. It'll likely be after the holidays when the weather warms up a bit, pretty darned cold out there to be wrenching and our time is going be eaten up by holiday stuff. Stay tuned.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 12-09-2013, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #224 (permalink)
Gas Huffer
MichiganMike's Avatar
Update:
Trans is coming along after figuring out our differential. The diff that came with the trans we bought wasn't going to work, so we sourced an open diff from a good friend locally. Got the adapter kit in along with a new clutch and PP. Starting to come together nicely, but quite a bit of work to go. Here are a few pics of the nice looking products we got from KEP:
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi
69 Porsche 911T - Project
04 Ford F-150 FX4 - Boris
Old 02-01-2014, 03:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #225 (permalink)
Gas Huffer
I may have jumped the gun a bit, but happy that it finally came in! I think it's appropriate!
Old 04-03-2014, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #226 (permalink)
Gas Huffer
radiators!
First started off with cardboard mockup radiator to fit in the car. then looked on eBay and bought a Nissan 280Z 75-78 L6 radiator which is very basic and has the height I want and its a 3 row for $120! Once I got the radiator I had it cut with a bandsaw for a nice straight cut. Then removed the leftover fins with a rat tail file and below they are nice and cleaned up. Need to weld on the side plates to both the upper and lower tanks of each. Then will drill out second outlet for each and weld in 1.25" tube. Also order some Spal 7.5" fans to mount on each.
Old 06-14-2014, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #227 (permalink)
Mikes car hasn't progressed as fast either of us would like, but at least she has a good home. I've been working like mad on my garage space so that I've got a good foundation for doing the complicated work of swapping the engine. Its taken a year but the Im just about ready to start with the swap.
In the meantime, we added a carbon splitter that we bought from eBay from a Nascar team. I cut and sectioned it down the middle and took out about 10 inches, then epoxied it back together with some dowel pins in the middle. Its a nice thick rigid piece that should give the bumper quite a bit of strength. I also added a black grill in the oil cooler opening and mounted the front license plate holder.
Soon I'll be dropping the engine in prep for the STi install, just as soon as I get my brother up to the Bay Area to help
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 07-17-2014, 10:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #228 (permalink)
porschetub's Avatar
Originally Posted by Etarga View Post
Stuff a Jake Raby 2.7L 4 banger in that baby and scare the 911 crowd ?
Why ?they cost an arm and leg?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-18-2014, 04:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #229 (permalink)
Gas Huffer
Rads have been completed, working on mounting and running lines:
Old 08-04-2014, 05:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #230 (permalink)
1984 Porsche Carrera
ozracer's Avatar
love this build something so different cant help but think what it would be like with PMO's
Old 08-06-2014, 12:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #231 (permalink)
Gas Huffer
Some updates to the car over the past weekend:
- Finished up Radiators
- Mounted them in the car with beefy brackets (top and bottom)
- Mounted fans on the radiators, and it all fits! Yahoo!
- Cut and welded oil pan and pickup tube about 1.5"
- Cut and welded coolant crossover tube to go out the other direction
Old 08-11-2014, 09:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #232 (permalink)
3 restos WIP = psycho
kenikh's Avatar
If you need any Subie parts, I have some pretty wild stuff collecting dust like:
  • Moore Performance equal length headers (for Evo IX turbo)
  • HUGE Bell water/air intercooler
  • STI air/air intercooler
  • Plastic Legacy GT intake manifold (reversible)
I guess I've been too lazy to try and sell them on NASIOC...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-11-2014, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #233 (permalink)
300hp 1800lbs is the goal
pksystems's Avatar
Awesome.
Just want to check... no issues getting new caps welded on the end tanks?
I have the same thing planned for cooling my subaru motor
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 08-11-2014, 09:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #234 (permalink)
Gas Huffer
Kenikh - Thanks, I'll keep that in mind!
pksystems - No issues yet. Pretty simple weld, just need to be sure not to hit a fin. May want to shield with copper or steel to be sure that the heat from the torch doesnt melt a thin fin, otherwise, not to hard.
Update:
- Old combo out and mounts or gone
- New alternator bracket fabbed
- New tight fitting belt
- Flipped intake manifold, almost complete
- Turbo mounted
- Exhaust started
Old 08-19-2014, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #235 (permalink)
Gas Huffer
Exhaust almost done!
Old 08-31-2014, 10:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #236 (permalink)
Gas Huffer
Old 08-31-2014, 10:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #237 (permalink)
Work continued this past weekend:
•*Made cooling pipes for each side of the car, 1.25" 16ga 6061 aluminum tubing
•*Added bleeder bungs at the highest points of each pipe
•*Finished the header on the engine, wrapped up the wiring harness, cleaned it up a bit
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 09-10-2014, 03:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #238 (permalink)
LJ851's Avatar
Bad Ass !
Old 09-11-2014, 12:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #239 (permalink)
toddu's Avatar
Nice looking welds!! With a MIG?
Notice in a previous pic, we have the same band saw. Using mine currently to build a home brewing rig :-)
Todd
'81 SC
Old 09-11-2014, 01:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #240 (permalink)
