AutoBahned
RWebb's Avatar
What is Your Holy Grail for Components on a 911?
the companion thread made me think about this
rather than a particular car, what would you want on a 911?
to provide an example, I'll go first
1. very low wt.
2. less wt. on the rear end - i.e. closer to a 50/50 than a 40/60 wt. distribution
3. more power
4. stiffer chassis
5. PCCB brakes
6. narrow, classic, fender profile
yes, some are more in the way of design specifications (top) than particular components (bottom) used to achieve the goals, but, since it's the internet, I thought I'd keep it loose
Old 10-15-2009, 06:36 PM
Driver
Noah930's Avatar
I don't know if I can narrow it down to just one Holy Grail factor on a 911. There's nothing particularly spectacular about any single part of a 911. Rather, it's the way all the parts come together for a unique driving experience that makes a 911 special, IMO.
1990 Black 964 C2 Targa
Old 10-15-2009, 06:39 PM
muck-raker
kidrock's Avatar
a Chevy motor. (Just kidding.)
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-15-2009, 08:04 PM
bavaria911's Avatar
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 10-15-2009, 08:51 PM
my set of Weidman deep 6's, 15x6's on the front and 15x7's on the back, should be done soon.
73 T Coupe, MFI, Aubergine, built back to E spec
Old 10-15-2009, 09:17 PM
AutoBahned
RWebb's Avatar
cool - diesel tractor pump - great idea for a sports car!
Old 10-15-2009, 09:19 PM
356RS's Avatar
I would say: Short Stroke high compression with MFI and a set of short gears to boot.
Mark Jung
Bend, OR
MFI Werks.com
Old 10-16-2009, 07:19 AM
dtw dtw is offline
GAFB
Yes, it was, as it turns out.
Several BMWs
Old 10-16-2009, 07:35 AM
naparsei's Avatar
5. PCCB brakes
Randy,
Just curious, but why? I know they work great, but the initial bite is a little off putting, and in some ways sub-optimal for street use. I have 2 cars with ceramic brakes and they brake like God reached down a grabbed the rear bumper, but even broken in, they aren't very progressive. Great for the track, tougher for the street, imo.
'74 Euro Carrera * '64 356SC Coupe
Old 10-16-2009, 08:12 AM
Crusty Conservative
silverc4s's Avatar
1. Under 2000 lbs, wet w/o driver
2. Over 250 whp, employing MFI
3. No frills, but licensed for the public roads
4. Momo Prototipo wheel, Rennshift shifter
5. 17" Fuchs
6. Modern brakes
7. All of the Elephant &/or WEVO gear I could afford
8. RS level interior trim
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-16-2009, 08:16 AM
3 restos WIP = psycho
kenikh's Avatar
'78 turbo brakes
7R wheels
Big bore ITBs
Cross-drilled 66mm crank ground for GT3 rod bearings
GT3 spec moly or Ti rods
High quality equal length header
Nickie cylinders
Race prepped 73.5 7R case
Supertec head studs
CNC ported heads from a top shop
Custom Dougherty Racing cams
Every engine coating known to man
Knock controlled ignition
Twin plug dizzy
Engine Management
Coil on plug spark
Full Elephant Racing suspension
Wevo 915 short geared tranny w/ LSD, gateshift and spray bar cooler
Fabcar modded oil tank
993 oil cooling system
And the impossible to find: modern 15" performance street tires
Good thing I have almost all of these now... Maybe I can start building my motor.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-16-2009, 08:41 AM
scarceller's Avatar
HP to Weight ratio.
As much HP with as little Weight as possible.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-16-2009, 08:44 AM
AutoBahned
RWebb's Avatar
Originally Posted by naparsei View Post
Randy,
- they are much much lighter (think I listed that as goal #1)
IIRC, they are now coming out on some MB models, so I expect the grabbiness (initial bite) is not inherent in the technology.
Old 10-16-2009, 11:06 AM
AutoBahned
RWebb's Avatar
OK - I'll add: a lighter motor! (maybe the Chevy joke is not so funny...)
The problem is how to do that - one bet would be to dump the cam chains & heavy tensioners in favor of the original idea - belt drive. Unfortunately, we'd lose some of that interesting mechanical sound...
Old 10-16-2009, 11:09 AM
petevb's Avatar
Randy,
What generation pads/ brakes are you on? The pads in particular have gone through a number of iterations to improve cold bite- if you're not on newer pads you might try them to see if they help your issues?
Old 10-16-2009, 11:32 AM
muck-raker
kidrock's Avatar
good point. I've been wondering to myself lately what these motors would be like with gear-driven cams, as opposed to the chains & tensioners.
STONE
naparsei's Avatar
Pete,
I have the original pads on an '08 GT3. It's not undriveable or anything (to the contrary!) but the initial application is tricky when you aren't thinking about it. I don't mean to overstate the case. Is there a newer iteration of pads that help? It's a little abrupt, but not as bad as F430 with composite ceramic brakes.
Old 10-16-2009, 12:10 PM
jluetjen's Avatar
One of these to put the engine and tranaxle into...
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-16-2009, 12:20 PM
(the shotguns)
berettafan's Avatar
1950lbs
260 +/-hp
69-73 chassis, std flares (no RS)
no sunroof
GT3rs seats OR an aluminum kirkey like seat w/ removable wings and period leather basketweave upholstery.
roll bar/harness bar
hoosier a6's on 15x7's
sitting at the starting line of a 2 minute hillclimb
Old 10-16-2009, 12:21 PM
boba's Avatar
Lightweight reinforced Tub
Coil over suspension
Centerlock hubs
Modern brakes
Duel master cylinder w/balance adj.
Old 10-16-2009, 01:49 PM
