Tire's worn out or???
So, the boy and I drive to a DE/Autocross, no issues 'cept some firmness in the tires when we start out (Hankook RS-2's at the wear bars in the rear and getting close in the front), 275 mile trip, smooth, no issues. Get to the venue, drive three 20 minute sessions, drive to hotel, all seems normal. Next morning, drive to venue, we get a droning/rumble (I can feel it in the wheel), starts at around 60 or so. Seems to go away as we drive. Drive event, no issues. On drive back home, I notice it just seems louder (road noise) then I am used to, at speed (85-ish).
So: Are the 1.5 year old "Kooks worn out (heat cycled to death, four or five track days, 2000 miles of street driving, 8 AX's) or is something else amiss? All else on the car felt normal, no gushing leaks, heat issues, boots look good, just this droning noise at speed. Thanks Scott PS the boy drove his first track event one day after getting his liscense. He IS the man. |
i would climb right under and take a real close look at the inside tread .. i bet your chorded..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Formerly known as Syzygy
Doh!!
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Possibly lost a wheel weight?
Adam Jackson '75 911 Targa S Silver Edition |
Designer King
Could it be wheel bearings?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I'd second this call. Could be dry or plumb worn out. I'd remove them, clean and inspect. If they look OK, repack with good high temp synthetic grease and put them back in and go for a drive.
Tony G 2000 Boxster S |
Just a suggestion... There's a good chance that one of your wheel weights came off. As a precaution you should cover each wheel weight with foil tape as heat generated from the brakes can loosen the adhesive of the wheel weights.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
My money would be on a wheel bearing, perhaps in a front wheel given that you feel the drone though the steering wheel. Maybe its worth getting the front of the car on axil stands and seeing if you can wobble either wheel in the 12 o'clock - 6 o'clock plane. That might not be the only test to diagnose wheel bearings, so it might be worth doing a search on this.
The only other thing which I can think of which it might be is a sticking front caliper. Does the drone go away briefly if you stab the brakes?
Charles '84 911 3.2 |
So we put it on the stand, pull the wheels. After a short drive to the shop, the front brakes are dragging badly. Water in line. Funny, we didn't notice any undue brake fade on track.
Rotors might be warped. Opportunity for slotted upgrade and some new pagids? Note to self; Bleed after EVERY EVENT. So we'll flush and refill and R and R wheel bearings. It's been 17,000 miles since this was done, prolly about time. |
Schleprock
What Pagids are you using? If Orange, might want to change and save yourself another set of deposited rotors in the future. I'd try cleaning the rotors with an abrasive material to remove the pad layer and see if they're "unwarped"
For future reference, wheel bearing actual problematic wear/failure is easily detectable by taking long sweeping corners at speed- not that high of a speed, either. You'll hear the bearing talking to you and then it's just a matter of finding which one it is. It's not always the bearing you think it is. Just experienced this front wheel bearing guessing game at Nelson Ledges w/our POS BMW Lemons car.
Kevin L '86 Carrera "Larry" |
The verdict
So we dig in to the wheels today, and find some worn out bearings on both sides. Replace both bearings,, rotors are within spec, (replace at next pad change with some slotted ones) pads ok, bleed system and replace with new Super Blue. Problem solved. Brakes drag a bit when hot, we're told by Bruce Anderson this is normal up to a point. Dragging quits after brakes cool a bit. Car still roles easily forward and back with "dragging brakes".
If anybody is interested sbm |
Designer King
We're interested. It's always best to follow up on a thread by posting the outcome. Now we and anyone who searches in the future will know.
