JR |
Are the tires directional? If not, have you tried swapping the fronts. I had a car with a failing tire, and it was all I could do to hold the car straight. When that tire finally died and I switched a new tire on the car went arrow straight.
I can see the car possibly pulling if the fronts were switched and they were unevenly worn somehow. |
I was thinking of doing a front tire swap to see if that helps straighten her out.
1980 911 ROW SC Coupe 2014 BMW 328i touring 1999 Porsche 911 C2 |
@Javadog
It's not a subtle pull; if you let go of the steering wheel in the left lane, a few seconds later you've switched lanes and are heading for the curb at an angle. I never had that problem before; now I'm constantly correcting to the left. Steering is also heavier to that side; around a left corner the wheel seems to fight to the right. @Mike Thanks, Mike. I considered that possibility, but there is no uneven tire wear and tire pressures are normal. @Magnumpi Does your car drift gradually to the right, or is it more of a sharp, lane change type movement? Last edited by Fassi; 11-06-2009 at 11:33 AM.. |
@berettafan
That's right, you did offer the tools; sorry about that. Did you use the tools for your own installation? Don't misunderstand me, if the guy has another way to properly install the bushings, great; I'm not a cheerleader for the Elephant tools. My problem is that he hasn't told me how he did it and seems oddly defensive about it. I'm going to have his worked looked over by another shop and we'll see. I hope it's not more than an alignment issue, but his attitude is not very confidence inspiring. @Jaskas If he had similar tools, he could have shown them to me when I asked him about it at the shop, yeah? |
(the shotguns)
no doubt you need to just get the car somewhere else with an instruction to check the work and get the alignment right.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
At this point, you have six pages of people confirming your suspicion that things are definitely not right. If I were you, I'd make an appointment with one of the specialists in your area mentioned earlier in this thread. After spending as much as you have, another $300 to $400 will be well worth it to have a perfectly aligned and weight balanced car. I rebuilt my suspension about four years ago and had the car corner balanced and aligned (and again just about six months ago at TRE), and it drives perfectly - no pull in either direction.
That's the plan, Scott, thank you.
Thanks, guys, for all the great advice and moral support. |
My tires are newer, less than a few thousand miles, and show no signs of uneven wear either. I'm not expecting any miracles when I swap the Left and Right fronts, but I'll give it a shot anyways. I should mention that I'm a newer owner of the car unfortunately without much history as to the suspension upkeep. My mechanic said things all looked original but were within tolerance when he safetied the car. All I've done is get turbo tie rods put on, and the four wheel alignment. The car was also pulling before the new tie rods and alignment.
Positive caster also is what gives you a self-centering tendency for the steering. The more positive caster that you have, the more self-centering effect that you get and the more the steering effort will load up in a turn. JR |
No, the front castor did not get set during my alignment. I chipped away all the black sealer around the shocks in the luggage compartment before going, but the technician said the camber/castor was "just fine", they just adjusted the front toe (new tie rods just put in) and rear castor/camber/toe. Unfortunately, they weren't a Porsche shop so I am planning on trying to locate a local Porsche specialist for a re-alignment.
In that case,
I'll bet all they adjusted was the front toe. Obviously, the camber or caster isn't correct, given the symptoms you have, and I'll bet you lunch they have no idea how to use the eccentrics in the rear to adjust anything. By the way, there is no rear caster to be set. Jeff |
I am a relative newbie in the Porsche world, but I had a similar pulling experience in the BMW I rebuilt. After chasing it around under the car, I tried swapping tires on the front. Turns out there was some slip of the belt in one of the tires which caused it to pull the other way.
Good luck. |
(the shotguns)
Any updates on this?
Mechanic supposedly re-installed the front bushings and realigned. Total toe was set at .17 and the car was test driven. Total toe shifted to .49 (out of spec) due to "settling." Car was realigned. Stance is perfect and the suspension is quiet.
The situation is somewhat improved, but car still drifts to the right, and the left wheel still wobbles at full left lock (although a bit less noticeably). Mechanic thinks it's a dragging right caliper. He suggested new tires and a caliper rebuild. |
Ready for a new mechanic yet?
JR |
(the shotguns)
Ck brake pads if in a while. Should be clear difference between l/r.
WOW... All the time from experts like Grady and Chuck... 120 posts... and your still with the same mechanic and still talking about settling bushings.. and still probably havent had a proper alignment and corner balance... they need to be done together...
I can tell you I did a complete Elephant install myself... parts alone were 3k... and when I had the alignment done, the CB was off... way off... it drives straight as an arrow... it is a street car... porsche designed the car to get a CB... if they didnt want you to get one.. the factory wouldnt recommend it... why do you bother to bring up your issue on pelican if you just ignore all the experts... i am no expert... but you should probably get a new mechanic and do what people like Grady tell you to do... sounds to me like you have moved into brakes... your mechanic is enjoying taking your money im sure... If the car didnt do the drifting and wobbling before your install... then its not tires and brakes... its directly related to what was done... Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 12-17-2009 at 07:50 PM.. |
