Horn Randomly FREAKS
I put in a Momo wheel in a long while ago, just as directed by pelican, and HOLY COW, wtf horn. It worked fine for 2 days, maybe less and then randomly started blaring until i disconnected it and eventually disconnected the horn(the wheels sweet). I must have gone over fifteen different sets of directions and looks like i did everything fine, and works fine when i have the original horn in. Does my alpine car alarm just hate Momo? It makes me so sad...
Justin 911SC Targa '08 Lancer '05 Triumph Thruxton |
The same thing happened to me. Check the screws that mount the horn to the wheel. You'll probably find if you tighten one of the screws, the horn will sound. I think they have an insulated o-ring. I ended up rotating the screws until one didn't ground the circuit. Haven't had any problems since.
1987 911 Carrera 2006 Audi A3 |
also look carefully for strands of wire that may have accidentally fallen in there
81% stable 67% of time
Mine start blaring on its own initiative in Athens, GA, at a stoplight, with two lawmen standing on the opposite corner. They were amused. Problem came and went until I found the ground wire spade connector could make contact with the hot ring under the (930 wheel) button; bent the connector outward a millionth of an inch and problem stopped.
I also had that problem when I installed my MOMO wheel last year, check that GROUND wire, and make sure it is connected tightly!
GL! Rod
1989 911 Targa M491 1980 Triumph TR8 (sold) 2006 BMW M3 (Interlagos Blue) |
winter
As others have stated, it's grounding someplace. Forget the directions, you have something else going on. Disassemble and teach yourself how the system works, upon careful examination you'll find the issue. The system is simple and easy, you'll be able to sort this one out. If you have problems, post pics of your setup here. We might be able to spot something you've missed.
Good luck!
Tom '76 Targa |
Member 911 Anonymous
Post pics and we can walk you thru it.
+1 grounding somewhere ergo HONK, HONK HONKITY HONK!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
When this happened to me, the horn spring assembly had cracked, and it was grounding there.
Navin Johnson
Every time I made a right turn the horn would sound... My then girlfriend and I would crack up.... "right turn coming" Maybe you had to be there...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
LOL, nice and clean joke, buta bump
