Free minder
![]() Currently $99 at Northern Tools, but if you shop a bit, can find a better deal (mine was on sale for $60 at pepboys). The advantage of an ATV lift is no engine balancing issues during removal, and then you can use it to lift the motor to attach to an engine stand. For beer, I used Corona, but I recently found out Sam Adams does work too.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 01-30-2010 at 07:03 AM.. |
I'm having a problem discnnecting the hard oil line at the passenger side rear of engine.
I've put everything I've got into it and it won't go. I've also tried everything but a torch to get it to go. It's stuck. Any tips?? |
what are you cranking with? two big 15" adjustables are a great 2nd choice if you dont have a friend that owns the huge box wrenches.
leverage is your friend right now.
poof! gone |
I got it finally, I just needed more leverage
I don't know why more haven't figured this technique out:
If you're not using a lift, I find it much better to raise the entire car to the same level, making the rear jackstands under the T-bars the determining height. You'll probably only have 20-something inches clear under the rear. You get the engine ready to drop, and actually start the process a couple of inches while the car is LEVEL. Much easier to work in this state. THEN, you start to lower the FRONT end SLOWLY while someone is pulling back the engine and lowering that jack. This takes two people, or a lot of back and forth by one. When the front end is finally on the ground and the engine is clear and dropped, the a$$ end will be up in the air at the 36" + to roll it out. Starting with the engine much lower to the ground and level is a much saner beginning, in my opinion. It works, plain and simple-I've done it both ways-level is better.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
My last drop, I dropped the engine while the entire car was level, as Ed suggests.
The car is stable, and not going to tip over. After the engine is basically at full drop, I lower the front of the car, which raises the rear valance. It will clear even a 911SC. No need to remove the bumper or anything. When re-installing the engine, car is level. Makes installation a breeze. |
I have dropped my engine and trans, three times by myself. I use a ATV/motorcycle lift from Sears with the big jacks on the back end front, nice and level. It's easy, the longest part of the drop is labeling all the electrical and fuel/vacuum lines. I had to use 4 by 4's to help increase the height, and it worked out well, with no problems. Wayne's book helps. I had to remove the rear cowl, but that was simple.
'77 930 euro project |
Several ways to this job..........
Gregg, There are several different good ways to remove the 911 engine from the car. Most convenient and safer way is the use a hydraulic lift. In the absence of a hydraulic lift, using ordinary garage equipment like floor jack, ATV lift, hydraulic table, furniture dolly, or an engine cart are some of the most commonly used by DIY's today. And probably a few techniques or methods that others used in doing an engine drop. It is important that you choose and select the method that you understand and comfortable implementing it. Dropping the engine is your main goal but SAFETY should never be over-looked. Before acquiring a hydraulic lift, I have this gizmo that I used to do engine drop SOLO. And have been a valuable tool for some of my local friends doing an engine drop. ![]() ![]() ![]() While many have safely used floor jacks, for me, engine cart offers a much safer and secure handling of the engine/trans during extraction specially when you're working solo. The most important thing is to be able to get the motor out SAFELY. Removal of the rear bumper and valance is a good way to minimize the needed height (clearance) to clear the engine out. My only advise to you this time, is have someone around when you first tackle this project. While I do this solo removal/installation all the time even without a hydraulic lift, I don't recommend it to others. Try to have a second safety net like putting wood blocks under the car. In my case, I had jackstands under the lifting bars if something unexpected occurs. Keep focus and you'll be fine. Tony |
