Crankcase blowby exits the engine at relatively high velocity. Routing this into the oil tank allows most of the liquid oil to separate from pressurized gases/air. The oil tank provides an area that allows the blowby/oil mist flow to decrease so a smaller tank can further separate liquid from vapor.
Another plus 1 to not allow condensed H2o, raw fuel, other liquids, etc. to drain/return to the crankcase. Sherwood Last edited by 911pcars; 08-21-2018 at 08:47 PM.. |
Still here
scumbag
the fuel and water will be vaporized and should push right back out of the tank into the can whereas the oil will be droplets and fall into the tank as soon as the velocity of the air/oil/water/fuel mixture starts to slow down or cool off.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Schleprock
I'll add that the volume of oil discharged by the crankcase breather can be a major amount of oil that no catch can is able to hold. It's so much oil that it must be returned to the tank. It's also very advisable that the hose from the crankcase breather is humped upward to use gravity to limit the amount of oil that the engine pukes out. Basically at lower rpms the oil can climb up the hose and then slide back back to the crankcase. But at sustained high rpms that oil will keep coming and go all the way to the tank.
In racecars that have a forward mounted tank in the trunk's smuggler's box, the crankcase breather hose is typically routed along the roof line (usually strapped to the roll cage tubing) and that helps limit the amount of oil discharge. Even with the high routing, it still spits a bunch of oil into the tank. I've heard racers that use the clear fiber-reinforced hose say they're shocked how much oil they can see going thru that hose.
Kevin L '86 Carrera "Larry" |
AN sizing is 16ths of inch I.D.
-3 = 3/16" -4 = 4/16" (1/4) -6 = 6/16" (3/8) -8 = 8/16" (1/2) -10 = 10/16" (5/8) -12 = 12/16" (3/4) -16 = 16/16" (1) -20 = 20/16" (1 1/4)
78 911SC Targa, GP White |
For those of you with Moroso catch cans, are they serviceable? Product description states " internal baffling with mesh media for air-oil separation."
Can the mesh media be cleaned out to make sure they don't clog? I just have a filter attached to a hose extension from fill neck currently. I get a modest drip here or there so don't realy _need_ a catch can. Just want to make sure that I don't create a problem I don't have by adding a catch can. Thx. |
Hi all,
Can I use a catch can for CIS system? Thanks, Khuong |
PCA Member since 1988
Yes, but why would you want to?
If you have the early CIS where the breather hose goes into the right side of the air box, then no changes necessary. If you have later CIS, where the breather hose goes into the intake boot, then you need to plug the hole in the intake boot.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
