Keep the Shiny Side UP! Pete Z. |
Ok, looks like new main and pinion shaft bearings.
Another question - if I swap out the existing open diff. for a ZF limited slip do I need to reset or check the pinion depth? I know I will need to check the carrier bearing pre-load but that is fairly DIY as opposed to the pinion depth.
Steve '75 non-sunroof coupe. 3.5 twin plugged engine in progress |
Thanks Pete, The Wiki is going to be indispensable. Thanks for your input and work on the Wiki
