Paul Shepherd's Avatar
Smile Electrical Help
Hi everyone
this is probely pretty basic for anyone with some electrical knowledge
the fuse that my air conditioning is on works ok when driving normally but give it a bit of stick and the fuse blows...does anyone have any ideas please
Old 07-26-2010, 10:09 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I had to look in the Wiki dictionary to understand "Give it stick". It means to abuse it - to beat it. Cool.
At first I was thinking your voltage regulator is bad. Under high RPM's the alternator may be generating too much voltage and blows the fuse - don't know if amperage is increased in this scenario. Also not sure how many amps it takes to hold in the ac clutch. If it is a big draw the perhaps 14 - 16 volts (vs. 13 or so) is enough to blow the fuse. Test is simple. Test voltage across the battery terminal when idling. If it varies more than one tenth volt the v-reg is bad. Mine varied a volt an a half before being replaced.
Another school of thought is that under acceleration wires can move and may cause a short. You may have a wire that is rubbed bare and touches ground only when accelerating. Check the main wire that feeds the a/c clutch.
Old 07-28-2010, 04:27 PM
thought I would post an update to this problem.
I had put it in the to hard pile and just did not use the a/c. I have also had a broken seat switch that I replaced last weekend and it seems to have solved the problem with the a/c.
The old switch once removed and shaken had a few loose parts inside that I think where shorting out as the seats are on the same fuse as the a/c.
1984 4.7 928 S2 owned 2015 to present
1986 3.2 911 Carrera Coupe owned 1996 to present
1974 2.7 911S Targa owned 1990 to 1996
1980 3.0 911 SC Coupe owned 1985 to 1987
Old 04-04-2013, 05:33 AM
