Don DeCristofar's Avatar
Unhappy car quit running
out for a drive and my car stalled on highway no indication of problem, I think the cd unit failed no spark does anyone know a quick test before I go nuts my manual doesn't explain tests clearly 77 911s
1977 911S 1965 bug 1990 454SS sold
Old 09-19-2010, 06:01 AM
Oh Haha's Avatar
Does it crank?
How did you test for spark?
Check relays first. The fuel pump realy is in the front trunk. Swap it with the horn or window relay and see if it starts.
Pacific Blue
Wayne
Old 09-19-2010, 06:04 AM
every thing works ,havent started cking yet and will ck relays didn't think of that, checked for spark at the points
Old 09-19-2010, 06:12 AM
cked relay didn't start
Old 09-19-2010, 06:23 AM
Are the points adjusted correctly? I like to start with the easiest things first.
Here's some troubleshooting tips on a 77 - including the telegraph test for your CDI:
http://forums.pelicanparts.com/porsche-911-technical-forum/543921-cdi-fuel-issue-77-911s.html
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 09-19-2010, 06:39 AM
19 years and 17k posts...
azasadny's Avatar
Check your wiring, especially to the CDI. Mine did this a few weeks ago and a wire had worked itself loose...no warning.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-19-2010, 06:53 AM
Banned
I agree with Walter. I had the same problem one day. Car just stopped, would crank but no spark.
Points had closed.
Check that first. It is free.
Old 09-19-2010, 07:40 AM
I have narrowed it down to perma tune mod, transformer ohms out, points good fuel relay clicks and pump runs, thanks for the help !!!
Old 09-19-2010, 08:33 AM
