7T7911s's Avatar
High beam switch
Everytime I hit a bump, the high beams come on.
Can this item be repaired?
Kenny
Old 08-04-2010, 02:37 PM
E Sully's Avatar
http://forums.pelicanparts.com/porsche-911-technical-forum/520402-headlights-only-work-high-beam.html
Common problem.
Ed
1973.5 T
Old 08-04-2010, 03:01 PM
But what about no high beam. Switch, or wiring?
Old 09-19-2010, 02:57 PM
After you install a new hi lo switch put a pair of relays in
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-19-2010, 03:01 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by rstarga View Post
after you install a new hi lo switch put a pair of relays in
+1
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-19-2010, 04:06 PM
HarryD's Avatar
Yep: http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-19-2010, 06:33 PM
Detached Member
Hugh R's Avatar
Easy fix. Try electrical contact cleaner first, you can always pull the switch.
Hugh
Old 09-19-2010, 06:40 PM
If you find that you have no high beam, or no low beam, try using some snap ring pliers to spin the retaining collar for the light switch, then pull the light switch out backwards, and retract it out of the dash. Letting it hang down, you can inspect the electrical contacts. You should check and clean the spade connectors, which are probably either loose, dirty, or both. It's a quick 5 minute fix.
Old 09-20-2010, 01:26 PM
Hodgey's Avatar
I took the covers off and opened up the contacts a little as indicated in one of the posts.......problem solved..
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 09-20-2010, 03:08 PM
