GaryR's Avatar
Send a message via ICQ to GaryR
915 differences?
Just read a post that listed some of the differences between the 915's in earlier cars shown here - (thanks Pete Z.)
915/06 = 1974 7:31 with FIVE forward speeds
915/16 = 1974 7:31 with FOUR forward speeds
915/40 = 1975 8:31 with FIVE forward speeds
915/43 = 1975 (Euro) 7:31 with FIVE forward speeds
915/45 = 1975 8:31 with FOUR forward speeds
915/48 = 1975 (Euro) 7:31 with FOUR forward speeds
How about later 915's? Was the 7:31 R&P standard in any of the SC's or Carerras? Was the gearing any different in a Euro vs. a US car?
Gary R.
Old 10-13-2010, 12:19 PM
Peter Zimmermann's Avatar
Hi Gary,
All later 915s ('77 911S - 1986 Carrera) had the 8:31 R&P and five forward speeds.
915/61 = '77S - '79SC Worldwide trans
915/62 = '80 - '83SC RoW
915/63 = '80 - '83SC USA
(Minor ratio difference between the /61 and /63 in 2nd speed, and between the /62 and /63 in 2nd and 5th speeds. The /61 and /62 actually use the same 2nd speed).
915/67 = '84 Carrera RoW
915/68 = '84 Carrera USA
915/69 = '84 M 491 RoW
915/70 = '84 M 491 USA
915/72 = '85/86 Carrera RoW
915/73 = '85/86 Carrera USA
(Minor ratio differences; /67, /69, and /72 used a different 2nd, 4th and 5th than the /68, /70 and /73. 915/67, /69, and /72 had oil coolers, the USA models did not).
Keep the Shiny Side UP!
Pete Z.
Old 10-13-2010, 01:08 PM
Bill Verburg's Avatar
How about later 915's? Was the 8:31 R&P standard in any of the SC's or Carerras? Was the gearing any different in a Euro vs. a US car?
8:31 was std from MY75 up
here are a bunch of 915s , from '72 -'86, If it's not here I have it.
Bill Verburg
Old 10-13-2010, 01:26 PM
GaryR's Avatar
Thanks Pete and Bill, exactly what I wanted to see!
Gary R.
Old 10-13-2010, 01:30 PM
RETIRED
Joe Bob's Avatar
Early 915 have a different case differential side cover and alloy which is less desireable.
2012 ML350 3.0 Turbo Diesel
Old 10-13-2010, 02:04 PM
zioo
Where can parts be sourced for a 915/16 1974 Base 911 Transmission? For example bearings and synchros and gears. Zioo
Old 11-03-2010, 06:38 AM
gearhead
Our host has a very good assortment of service parts for the 915.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-03-2010, 10:05 AM
In maintenance phase
daniel911T's Avatar
forgive the hijack...
I have been wondering if a 915 support bar (the bar with the tranny mounts) will bolt up to a 901 tranny? I would really like to have replaceable mounts.
Thanks!
Dan
Old 11-03-2010, 10:15 AM
onboost's Avatar
Thanks!
Dan
Dan, if I recall correctly, I don't think the 915 bar will work for you on the 901.
The 901 box and that of the 930 actually use a similar "support bar".. both with non-replaceable rubber mounts.
I too ran into the same issue with my 930. My mounts were very worn and I was just not happy with the thought of using them with the loads my car could generate.
I went with the mod/fix offered by Wevo and have been very pleased.
Check them out @
Welcome to Windrush Evolutions - WEVO - Porsche Products
Paul
RGruppe #180
Old 11-03-2010, 11:21 AM
AutoBahned
RWebb's Avatar
to use the 915 cross bar support on a typ 901/911 trans., you will need to make an adapter plate to match the mounting holes
you can then easily & cheaply replace mounts until the sun goes out
make the thickness of the plate so that the 901 shift shaft lines up at the level on the Z axis as the 915 did
I posted details on it before; dunno how hard it will be for you to search
Old 11-03-2010, 11:35 AM
onboost's Avatar
I knew someone had another fix.. couldn't remember what or who! Great post.
P-
RGruppe #180
Old 11-03-2010, 11:38 AM
daniel911T's Avatar
I incline toward the solution that allows use of factory mounts. However, when manufacturing adapters and paying other people to cut metal the price can get pretty high pretty quick. The WEVO solution may ultimately be cheaper.
That said, I think it's time to start looking for a 915 support bar.
Thanks, and I'll be looking for your thread on the subject,
Dan
Old 11-03-2010, 11:47 AM
daniel911T's Avatar
Randy,
I think I found your old thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/286513-type-911-using-915-support-bracket-mounting-adapter.html
However, I'm still left with a question. How thick is your adapter plate? (What's the Z dimension?)
Thanks!
Dan
Old 11-03-2010, 11:58 AM
AutoBahned
RWebb's Avatar
Great - glad you could find it
unfortunately I don't recall the thickness - BUT it was for a typ 911 trans. and a 1973.5 body, so you'd need to have measured for your car anyway.
I did not need to mill that piece of steel down any - I just used a commonly available thickness, cut it to size; added threads & had it powder coated.
start with 1/2 inch and see if that is about right - the coupler will obviate the need for an exact match (and I don't have my shaft exactly in the center... anyway)
Old 11-03-2010, 12:14 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Gary
I e-mailed you my Excel file on 915 trans gears and other info. I have two 86 trans here waiting for you to choose one. I'll pack in one of Matt's LSDs and ship for free end of January (on Dan's truck returning from Sebring). You know you want it!
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 12-13-2012, 04:25 PM
Porsche84's Avatar
Oops, my bad, an old post.
Jerry Austin
Old 12-13-2012, 04:31 PM
Very old post, but probably better than starting a new one, as there is some good info up top.
Question; are the gears from a '74 mag case 915 interchangeable with a mid 80's 916/73?
Pretty sure 1st is not, as the shaft design is different, but what about the remaining?
Old 04-14-2020, 04:04 AM
One thing I did notice, was that the teeth on the later box 2nd gear, look 'pointier' than the older box 2nd gear. I took some photos and when looking closely, it actually seems that the 2nd gear teeth from the later box, have a bevelled edge.. wondering if this was an improvement to the later boxters to increase strength or perhaps reduce noise?
(yes, the gears are on different shafts.. ie, later model gear is on older shaft and vice versa)
Old 04-14-2020, 04:31 AM
Porsche84's Avatar
Mikedsilva
IMHO, the gears are all interchangeable in 915 from 72 to 86. Yes, the input shaft changed but it it could be used in a later box, but I wouldn't. There were also improvements with dog teeth and sliders that should be considered if you are using early parts, but the gears are all interchangeable as sets. The pictures above are reversed. The input shaft with the sleeve touching 2nd gear is the later improved design, the photo below shows why they changed
Jerry Austin
Old 04-14-2020, 05:32 AM
Originally Posted by Porsche84 View Post
Mikedsilva
Thanks for the info.
Just doing a bit of searching and it seems that the 5th gear was a tad taller in the older transmissions too. That might come in handy.
Old 04-14-2020, 06:10 AM
