915 differences?
Just read a post that listed some of the differences between the 915's in earlier cars shown here - (thanks Pete Z.)
915/06 = 1974 7:31 with FIVE forward speeds 915/16 = 1974 7:31 with FOUR forward speeds 915/40 = 1975 8:31 with FIVE forward speeds 915/43 = 1975 (Euro) 7:31 with FIVE forward speeds 915/45 = 1975 8:31 with FOUR forward speeds 915/48 = 1975 (Euro) 7:31 with FOUR forward speeds How about later 915's? Was the 7:31 R&P standard in any of the SC's or Carerras? Was the gearing any different in a Euro vs. a US car?
Gary R. Last edited by GaryR; 11-03-2010 at 07:01 AM.. |
Hi Gary,
All later 915s ('77 911S - 1986 Carrera) had the 8:31 R&P and five forward speeds. 915/61 = '77S - '79SC Worldwide trans 915/62 = '80 - '83SC RoW 915/63 = '80 - '83SC USA (Minor ratio difference between the /61 and /63 in 2nd speed, and between the /62 and /63 in 2nd and 5th speeds. The /61 and /62 actually use the same 2nd speed). 915/67 = '84 Carrera RoW 915/68 = '84 Carrera USA 915/69 = '84 M 491 RoW 915/70 = '84 M 491 USA 915/72 = '85/86 Carrera RoW 915/73 = '85/86 Carrera USA (Minor ratio differences; /67, /69, and /72 used a different 2nd, 4th and 5th than the /68, /70 and /73. 915/67, /69, and /72 had oil coolers, the USA models did not).
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 10-13-2010 at 01:13 PM.. |
here are a bunch of 915s , from '72 -'86, If it's not here I have it.
Thanks Pete and Bill, exactly what I wanted to see!
Gary R. |
RETIRED
Early 915 have a different case differential side cover and alloy which is less desireable.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
zioo
Where can parts be sourced for a 915/16 1974 Base 911 Transmission? For example bearings and synchros and gears. Zioo
gearhead
Our host has a very good assortment of service parts for the 915.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
In maintenance phase
forgive the hijack...
I have been wondering if a 915 support bar (the bar with the tranny mounts) will bolt up to a 901 tranny? I would really like to have replaceable mounts.
Thanks! Dan |
The 901 box and that of the 930 actually use a similar "support bar".. both with non-replaceable rubber mounts. I too ran into the same issue with my 930. My mounts were very worn and I was just not happy with the thought of using them with the loads my car could generate. I went with the mod/fix offered by Wevo and have been very pleased. Check them out @ Welcome to Windrush Evolutions - WEVO - Porsche Products Paul
RGruppe #180 So many cars.. so little time!! |
AutoBahned
to use the 915 cross bar support on a typ 901/911 trans., you will need to make an adapter plate to match the mounting holes
you can then easily & cheaply replace mounts until the sun goes out make the thickness of the plate so that the 901 shift shaft lines up at the level on the Z axis as the 915 did I posted details on it before; dunno how hard it will be for you to search |
P-
I incline toward the solution that allows use of factory mounts. However, when manufacturing adapters and paying other people to cut metal the price can get pretty high pretty quick. The WEVO solution may ultimately be cheaper.
![]() That said, I think it's time to start looking for a 915 support bar. Thanks, and I'll be looking for your thread on the subject, Dan |
Randy,
I think I found your old thread: http://forums.pelicanparts.com/porsche-911-technical-forum/286513-type-911-using-915-support-bracket-mounting-adapter.html However, I'm still left with a question. How thick is your adapter plate? (What's the Z dimension?) Thanks! Dan |
AutoBahned
Great - glad you could find it
unfortunately I don't recall the thickness - BUT it was for a typ 911 trans. and a 1973.5 body, so you'd need to have measured for your car anyway. I did not need to mill that piece of steel down any - I just used a commonly available thickness, cut it to size; added threads & had it powder coated. start with 1/2 inch and see if that is about right - the coupler will obviate the need for an exact match (and I don't have my shaft exactly in the center... anyway) |
Grand Am/IMSA Data Guy
Gary
I e-mailed you my Excel file on 915 trans gears and other info. I have two 86 trans here waiting for you to choose one. I'll pack in one of Matt's LSDs and ship for free end of January (on Dan's truck returning from Sebring). You know you want it!
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Oops, my bad, an old post.
Very old post, but probably better than starting a new one, as there is some good info up top.
Question; are the gears from a '74 mag case 915 interchangeable with a mid 80's 916/73? Pretty sure 1st is not, as the shaft design is different, but what about the remaining? |
One thing I did notice, was that the teeth on the later box 2nd gear, look 'pointier' than the older box 2nd gear. I took some photos and when looking closely, it actually seems that the 2nd gear teeth from the later box, have a bevelled edge.. wondering if this was an improvement to the later boxters to increase strength or perhaps reduce noise?
(yes, the gears are on different shafts.. ie, later model gear is on older shaft and vice versa) ![]()
Mikedsilva
IMHO, the gears are all interchangeable in 915 from 72 to 86. Yes, the input shaft changed but it it could be used in a later box, but I wouldn't. There were also improvements with dog teeth and sliders that should be considered if you are using early parts, but the gears are all interchangeable as sets. The pictures above are reversed. The input shaft with the sleeve touching 2nd gear is the later improved design, the photo below shows why they changed
Just doing a bit of searching and it seems that the 5th gear was a tad taller in the older transmissions too. That might come in handy. |
