Bolt torque
It's early and I admit I haven't searched...
Anyone have the torque value for the bolts that attach the pressure plate to the flywheel for a Sportomatic clutch system handy? All I can tell you about them right now is that they're relatively small, like a number 8 or so bolt. Thanks in advance if you can help me out (yawn) I'm gonna go wake up now.
Scott '78 SC mit Sportomatic - Sold |
I beleave it is 18 ft lbs. I use a little blue lock tight also
Thanks Two Rivers.
Bentley manual confirms 18 ft-lb for the pressure plate to flywheel. I'll assume it's a good value for all pressure plates. Let the fun stuff begin....
