Straight shooter
Lapkritis's Avatar
I used o-ring grease on the seals when installing. Careful not to get grease on contact area of rocker shaft and rocker bush. Wipe on trailing seal on the shaft and receiving bore on far side of rocker area of the cam house. Prelube rocker a couple times after through the feed hole with regular motor oil.
No leaks or torn seals. Followed the Bruce Anderson method of final torque without holding backside to ensure it was parked.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-25-2013, 10:00 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
It seems our host no longer supplies these seals. Anyone know where I can pick up a set?
Old 01-27-2014, 03:56 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
Found em!
Thanks.
Old 01-27-2014, 04:42 PM
SCadaddle's Avatar
I can tell you, from experience, that at least on my engine we used a gun cleaning kit---read rifle or shotgun with long rod---chucked into a cordless drill to dress up the rocker shaft bores in the cam housings.
Old 01-27-2014, 07:09 PM
dshepp806's Avatar
I left this tasks (all of them) to dear P-wrench to address....so far so good! done!
Robert's Automotive, Bolingbroke, GA.....dr. Serge de le Breyere...
done right!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-27-2014, 10:03 PM
Flojo's Avatar
pardon, are these the right ones to order?
Product Information: 99-0579-052-M820
if not, please redirect me, as I'll need them soon, as the refurb will start soon.
or kindly advise what ring is best to buy.
thank you!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-12-2014, 01:21 PM
Flojo's Avatar
Tell me please
Old 11-13-2014, 12:24 PM
Straight shooter
Lapkritis's Avatar
Pelican Parts - Product Information: 99-0579-052-M820
Looks like you have it right to me.
Old 11-13-2014, 12:47 PM
Flojo's Avatar
Thanks!
Old 11-15-2014, 10:09 AM
Registered Minimalist
75 911s's Avatar
Can I buy 12 and just do the lower rocker shafts? It's $96 for all 24 and I don't see the top causing a problem...
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 05-11-2017, 08:50 AM
VFR750's Avatar
The uppers leak too. Mine did.
Yes, very expensive. And my experience is you need to replace them every time you pull them out.
They tear, and worse trap dirt in the groove which squeezes out during assembly, ruining the rocker bushing. Been there, done that.
But when they are new and installed, they work really well.
Old 05-11-2017, 10:29 AM
Taking it apart is easy
Jerome74911S's Avatar
What happened to all of the photos in the OP's original post? I see none, but do see later photos posted by others.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-11-2017, 11:42 AM
Tags
rocker shafts , rsr seals
