The clock is ticking!
After a lot of Pelican thread searches, I've got my clock working finally!
![]() The hole in the dash ![]() The inner bits. The capacitors were rotted, one fell apart in my fingers during removal of the innards. ![]() Bad parts coming out ![]() New caps going in. BTW, they can be replaced with 100 mf 35 W caps, not just 16 W. The shack didn't know this, but google did. ![]() Finished clock. Happily ticking away. Thanks to everyone who has posted on this before. The interior seems so much better now for some reason, though the second hand still won't work (I kid.)
1980 911 SC targa 1959 Triumph TR3A - sold Something new is on the truck... |
Brian,
You're my hero if you can make that "Cracker Jack" clock work... BTW: that's not a second hand, it's a "time marker" for lack of a better description. Maybe someone else can better describe its function.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Member 911 Anonymous
Start Fun Time Marker?
![]() BTW, Can you give the specs of those capacitors? Think of fixing my extra clock.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks guys and I was joking about the "second hand."
Fishrule, use 272-1028, the 100 microfarad 35 Volt caps (W above is a typo) Im out of town right now, but when I get back I'll write up some steps and tricks. Brian
Brian,
Thanks for the quick response. I look forward to the steps and tricks. -Kyle |
Easily Confused
Yeah, they were naive using a 16V cap.
One bad regulator incident and the clock would likely be fried. Great writeup!
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
OK, back home now with a real keyboard.
So, the first and most difficult part is removing the black clock face ring. I had to search for a very small, thin screwdriver to use. Push it in behind and twist, working around face and eventually it'll let go if you pull on it at the same time. Look at this for a better description of this part: Pelican Technical Article: VDO Clock Repair The back of my clock was different than he described though. Anyway, take off the face and store the screws securely (mine disappeared and after searching the garage floor for 30 mins I found them right where they were supposed to be, hiding in plain sight.) Next, unscrew the two screws on the back that hold the clock bits inside. Now a single wire sticking up through the back of the unit is left holding it in. Unsolder while pulling down and the parts will come out. I sprayed some electronic cleaner on everything too. 1 of the capacitors was obviously damaged. On the back side, unsolder all 4 pts for the two capacitors. Replace with two 100µF 35V Radial-lead Electrolytic Capacitors. They are marked +/- and both go with the neg pole to the outside of the board (which is marked neg also). Trim the wires after soldering in. Resolder the center back wire and replace screws etc. I found replacing the face ring pretty hard too but eventually it popped back into place with some cursing. Miraculously it is still ticking away. Hope this helps. Also, for VDO Quartz clocks only. Brian
thanks to this thread i got my clock working. total cost was $3.19.
one less thing on the "i gotta fix that" list. thanks again!
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
Strong work Drola, mine's still going too
Brian
For awhile I suspected that certain weird CIS problems may be caused by drifting or failed capacitors in the control box. Since most of the caps in the control box are film, I suspect the likelihood of that being the issue is lower than if the caps used were electrolytic. Some day I'll reverse engineer the circuit just for kicks.
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik |
Wow, you are lucky! My clock in my 85 only works on a road trip. Keeps perfect time. But then when I get home, Clock only works for a few hours after the car is shut off. Very strange. Nick
Formerly known as Syzygy
Well, if that aint the perfect excuse for going on a road trip...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Capacitor change worked for me!
Thanks for the great advice on fixing a VDO analog quartz clock in this discussion.
I replaced the two capacitors in mine using Radio Shack 272-1028 parts, and now it works great! The hardest part was opening the clock by prying open the flange around the front. I wish someone had a great MacGyver tip for that! Thanks again for the guidance. I would never have thought to fix my stalled clock by replacing capacitors. |
