boomerang's Avatar
rear sc tailights
Hey guys
anyone ever take apart rear lights to r&r
caulk or weatherstrip all dried up and non funcional
thinking of using a dow corning black silicone when putting back together
any other ideas dum dum 3m caulk ????
thanks
tull
87 cab
80sc Targa track car
73 project
Old 01-18-2011, 12:44 PM
I used plumbers putty. Seemed to work OK.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 01-18-2011, 06:47 PM
D911SC's Avatar
If you're talking about the seal between lights compartments I used a small length of irrigation pipe (left over from my home sprinkler system) and cut a slice down it. The pipe is very soft and presses nicely when the lens is attached. Far from OEM but it's tidy, cheap and works well.
For the backing plate I used a dense foam weather seal - hard to see on this pic but it also works well.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 01-18-2011, 07:19 PM
1980SCMan
Alan Lindquist's Avatar
Wow. How timely. I just took mine apart for the first time (have the car 5 years) to track down a dead wire and found plumbers putty. Don't know how long it's been there, but it all fell apart, was a mess, had degraded in places and bled around the inside and it all seemed kind of cheesy. I wouldn't recommend it for that environment.
I think the weather strip foam looks like a good idea and I have a bunch, so I'll try that.
Why the white paint instead of silver?
Old 01-18-2011, 11:15 PM
boomerang's Avatar
thanks
the putty in the back is from factory i believe
nice work exactly what i was looking for
tull
87 cab
73 project
Old 01-19-2011, 02:11 AM
D911SC's Avatar
It was white as factory - mine is a Euro which I believe is different to the US models.
Old 01-19-2011, 02:23 AM
AutoBahned
RWebb's Avatar
The earlier ones were silver - note the small hole near the bulb - my '73 has that also - it might be there to vent the "rear compartment" of the housing
Old 01-19-2011, 12:06 PM
Senior Member
Jdub's Avatar
I used white non-drying bathroom/shower caulk - worked great.
Were you amazed at the amount of dirt, gravel, and the like above and below this unit when you pulled it out? When I did this, I spent plenty of time washing, drying, and waxing inside and out before putting the taillight unit back in. Peace of mind.
I never found a good "chrome" type spraycan finish - maybe that white is the way to go?
'78 Targa in Minerva Blue
Old 01-19-2011, 12:56 PM
1980SCMan
You waxed inside? Really?
A pile of dirt came out. I was constantly siting in it and I'd sweep it up and then more would appear. Finally I went scraping around inside and knocked everything loose. There was a lot. A week ago I removed my rear wheels and cleaned up the wheel wells. I knocked a FULL dustpan of dirt out - piled high. Was tempted to weigh it. I took a photo of it and my daughter wanted to know why I was taking a photo of a pile of dirt. She just doesn't get it. She has no idea how much weight penalizes at the rear. But she's young. When she's older she'll respect not being heavy in the rear.
Old 01-19-2011, 01:02 PM
boomerang's Avatar
keep the junk out of the trunk
tull
87 cab
73 project
Old 01-19-2011, 02:14 PM
