Wew Wew is offline
SC Mutt
Wew's Avatar
Differential housing joint flange play
Hi all,
In the middle of my transmission refresh, and replace the seals in the differential.
Now that I have things back together I notice on the one side I have .6mm of in and out play. When I look at the pelican parts catalogue one image has the main stretch bolt going right in to the joint flange. The other image has that same bolt with a washer.
When I took it apart I do not remember there being a washer, nor do I remember the slight in and out play.
I have attached pictures of what I am referring along with the side. The other side of the differential has no in and out play.
Thanks,
Gary
Old 10-23-2014, 09:25 AM
