Zaphod32's Avatar
Question brake light sensitivity adjustment?
so, my problem is brake lights when pressing the pedal. The light is switched on too late, i.e I have to press the pedal really hard in order to get the light on. Any way to make this more sensitive?
// jyri aka Zaphod32
-from Finland, Europe-
Old 02-25-2002, 03:21 AM
What kind of brake system do you have i.e. what model of 911?
Bjorn, 911-65 911-77
Old 02-25-2002, 03:31 AM
Zaphod32's Avatar
Re: brake light sensitivity adjustment?
sorry, forgot to tell (btw, is mentioned in the web site)
it's 1966 911.
Old 02-25-2002, 03:37 AM
Super Moderator
cstreit's Avatar
Beeblebrox,
THere's a switch mounted to the pedal cluster. WHen you
depress the pedal, it releases a lever closing the brake light
switch. (I think it's a fail safe so the brake lights will stay on
if the switch comes loose.)
You can move it slightly, sounds like the lever is closed too long..
Bend the arm slightly to adjust, I don't think there is an
adjustment screw.
Chris
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-25-2002, 06:52 AM
Super Moderator
cstreit's Avatar
Ahh... Jadams, you're right, there IS an adjustment lever... See, it's too early for me to be handing out advice like a Shadetree hack...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-25-2002, 07:27 AM
Zaphod32's Avatar
Question
cstreit and jadams
Greetings from the garage
No, in fact there is no switch to the pedal cluster. There is some adjustment for the pedal itself, but that is already adjusted to the maximum.
Please note that this is a 1966 model 911.
Here's a poor amateur explanation with poor english...:
The pedal moves a rod that goes straight to the brake cylinder. Below the car there's something that looks like a pressure valve of some kind that has two wires connected to it. According to my understanding brake fluid goes through this valve and when a certain pressure is received it connects the two wires and TADAA! the two nice lights have been illuminated.
Let's get to the stupid question:
Ok. If... repeat... IF my theory is right (is it???), does the air from the brake system need to be sucked away when replacing this mysterious valve? Does this gizmo have a name (just out of my curiosity)?
My insurance for this summer starts at April 12th and that's when I intend to have my beauty running!!! Unfortz there's still quite a lot of snow around this part of the globe
Old 03-05-2002, 11:27 AM
