Don't forget there's no free lunch. You're not actually getting more torque out of your engine, you are just re-gearing your car.
With my rev limit and an OE tire, my car will go 67 in 2nd. On the stubby 15s it'll do 62 mph. That works out to just about perfect for 98% of AX courses. Flip side is driving on the freeway sucks as I rev to the moon to keep up with traffic. For track people, it may put you in different gears around your local track, which may be good or may be bad.
Matt - 84 Carrera |
Tires for 15" wheels?
Hi. I know that my engine is not getting more torque, I just want more usable torque delivered to the ground thats why I am thinking of smaller tires. My car also has a gear box ratio that with my RSR engine gives a real top speed of 171mph. I really do not need all that speed here in Norway and I do not drive much on Norwegian highway or freeway. So a rim size that could give me 20-25ft lbf more torque to the ground would be way better than the classic 911 freeway rocket ship it is now. Cheers Eskild Sent from my iPhone using Tapatalk Last edited by Litle brother; 12-17-2019 at 10:46 AM.. |
Both are good choices for an 8x15
thanks bill! --
Group -- looks like the tire options for a 7x15 and 8x15 fuchs wheel set that will be used on my '86 targa for summer-only spirited summer road, ax and DE purposes (205/50-15 front 225/50-15 rear) would include Yokohama Advan ao52 Pirelli Trofero R ??? From prior comments, I'm leaning toward the yoko advance ao52 Would use the 15" wheel set in conjunction with my current fuchs 16x7 front 16x8 rear wheel set running Michelin AS3+ tires (which would likely be preferable for road trips and my primary cold weather setup) Any other thoughts/suggestions? |
Oh no way I never noticed you calculate for that. Sweet.
Matt - 84 Carrera |
Hi again Bill. I have been looking at a tire calculator. It shows that the difference between the 225/50-16" and a 225/45-16" tire is .9" The difference between 225/50-16 and 225/50-15 is 1.0" This means that it is only a .1" difference between the 225/50-15 and the 225/45-16. SO, can I assume approx 12ft lbf more torque with the gearing from 225/50-16 to 225/45-16" ? Cheers Eskild Sent from my iPad using Tapatalk Last edited by Litle brother; 12-17-2019 at 10:44 AM.. |
205/50 & 225/50 compared to 205/50 & 225/45 ![]() 205/50 & 225/50 compared to 205/50 & 245/40, I don't like this one because of the staggered widths and heights ![]() 205/50 & 2225/50 compared to 225/45 & 245/40, only thing here is that the wheels would be wider for best results
Consider federal rsr-r 205/50 and 225/45. Cheap 200 treadwear streetable sticky tire. At approx $450 for four corners they're worth a try. Edit: actually they were actually <$400. Only autocrossed them once so far but I was impressed. I usually run re71r. Sent from my iPhone using Tapatalk Pro Last edited by JCGMS; 12-23-2019 at 11:54 PM.. |
There are a good selection of 200-treadwear tires in 205/50-15, because it's the spec Miata tire size. (And 200-TW is the lower limit for street classes) RE-71R is super popular among autocrossers, and the Falken RT-615K+ is a fair bit cheaper if you don't mind being a second slower.
The sidewalls on a 205-50 not as tall as one would think "looks right", you'll see some air between the tire and fender, but hey, they're light and the lower gearing is helpful on short tracks. |
Bridgestone re760
Part number 10347006 In 205/60-r15 Available in Mexico. I live near boarder. One day I might go down and pick up a set. Anyone else see these state side? |
![]() ![]() ![]() 225-45-15 Rear 205-50-15 Font |
pre-h2o, looks NICE -- what tires are those? 15x7 and 15x8 rims?
thx |
Thanks Darrin......
they are Hankooks...... 225-45-15 REARS 205-50-15 FRONTS YES...... REARS are 15x8 FRONTS are 15x7 |
