Melman's Avatar
What transmission do i have
I would like to install a short shift transmission kit ....i have a 1977 911 with a 5 speed .....how do i determine what transmission I have.
thanks Jon
Old 10-03-2011, 01:31 PM
schumicat's Avatar
you have a 915.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 10-03-2011, 01:35 PM
Oh Haha's Avatar
Get the factory short shift "kit" unless you go with an aftermarket setup like a WEVO.
Lots has been written on the subject but I'll just add that our gearboxes DO NOT like to be speed shifted.
You must learn to pause between 1-2 shift. If you try to beat the synchros you WILL be replacing them.
I speak from experience, my friend.
Pacific Blue
Wayne
Old 10-03-2011, 02:49 PM
efhughes3's Avatar
I'd stay away from short shift kits, and focus on making sure you've got fresh bushings in there and the coupler is adjusted. Seriously, there are better things to spend your money on. If your trans has any weaknesses, they'll be accelerated with the added force needed to shift the short.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-03-2011, 03:17 PM
Melman's Avatar
Thanks for the input ...im going from shifting a mazdaspeed3 turbo to a 1977 Porsche .....maybe i need to learn how to drive it properly.....it just seems like a really long stroke and a little sloppy.
Old 10-03-2011, 03:25 PM
efhughes3's Avatar
It will be a longer stroke, but it doesn't have to be sloppy. Note what I said about bushings.
Ed Hughes
2015 981 Cayman GTS
Old 10-03-2011, 03:27 PM
Oh Haha's Avatar
+1 to what Mr. Hughes posted.
My DD is Mazda Protege5 so I understand completely the difference you feel.
I have also customized my 911 shifter/guts to what feels best to me. Others probably wouldn't like it.
Pacific Blue
Wayne
Old 10-03-2011, 04:29 PM
Peter Zimmermann's Avatar
Ed is right on the money with his comments. I think that it might be a good idea, if you have help within driving distance, to take your car to a reputable independent and have them help you sort any problems. You are dealing with a car that is more than 30-years-old, and still suitable to use as a daily driver. Be kind to it, and it will be kind to you!
Keep the Shiny Side UP!
Pete Z.
Old 10-03-2011, 04:38 PM
Melman's Avatar
My intention is not to speed shift or abuse the car...just tighten up things a bit...it was my understanding that it was later offered as an option because it was a desired feature.
anyway thanks shumicat for identifying my transmission.
Jon
Old 10-04-2011, 05:14 AM
efhughes3's Avatar
Porsche loves to add up the options on new cars. That doesn't mean a short shift is good for a 35 year old trans with however many miles you have now.
Ed Hughes
2015 981 Cayman GTS
Old 10-04-2011, 07:48 AM
